Question about Dehumidifiers
Best way to relight the pilot without peezo ignition duct heater
Cx900 series central heatiing system I want to relight the pilot peezo not working asnd I do not have a manual
  • 34 Answers
You need to hold down the pilot button all the way down (turn selector to pilot).
When pressing the pizo count to 5 then press and repeat. It you just click it constantly you will lose your mind.
Posted on Jun 07, 2010
Why dose drum spin when furnace is not on?
Usually the unit is mounted to the cold air return (cold or intake air) and the round hose is then attached to the plenum (hot or discharge air). The humidistat is usually mounted just above the unit onto the meta plenum, unless you have a control somewhere else or your main t/stat has that capability built in. Its usually wired in with the furnace 24Vac control (or whatever yours happens to be) so that the unit only comes only when the furnace is on.
Dec 08, 2014 | Honeywell HE120A Whole House Humidifier
How does a humidifier pump stop
if your talking about a humidifier that's connected to a hvac system , there are two basic types , one uses a wheel similar to one a small pet rodent would exercise its self on , but this one is covered with a mesh that holds water, and a motor not a rodent turns it , fresh water is maintained in a dish in bottom of unit by a level activated valve ,it's activated in two methods one by airflow switch (paddle) and another by being connected to blower motor of air handler(electrically)
the other type is nozzle type , these need to be mounted in long straight runs of main duct work not more than ten feet from furnace (heat) these simply have a air flow switch that opens a valve to let house water into nozzle in duct , much smaller than 1st version unit
Jul 02, 2014 | Kenmore Dehumidifiers
I need an instruction manual for a Kenmore pump system dehumidifier. Could you help me by telling where i could get one?
If you have the correct Model Number, you can find it a Sears Parts Central.
Thanks for choosing FixYa.
Aug 02, 2011 | Dehumidifiers
Can i use the dehumidifier without the additional heater? OR how can i improve the performance of the dehumidifier without increasing the output of the heater?
Emma, your dehumidifier doesn't have a heater. I think you are confusing the Thermometer button as a heater. The Thermometer button is for setting the the ambient air temperature in the room, the unit is running in. It doesn't change the temperatue in the room one way or another. It's not necessary to set it, unless you're operating the dehumidifier in a basement. That's the only time it would affect the unit's performance.
I hope this helped you.
Jul 12, 2011 | DeLonghi Dehumidifiers
We moved and cannot find the manual. It is brand new and I cannot fighure out how to keep it running without the manual.
Manuals can be downloaded and printed for Kenmore appliances online at Sears Parts Central.
Hope this helped you.
Apr 27, 2011 | Kenmore 54351 Dehumidifier
I have an Aprilaire 1750 installed inline with my upstairs central air system in the attic. The unit's ducting appears to be installed as indicated in the installation manual, but when the unit is running...
Your dehumidifier is likely working correctly. When operating and removing moisture, a dehumidifier will supply warm/hot air to your house. Your dehumidifier moves less air than your A/C, so your supply ductwork in your house is oversized for the dehumidifier. This will lead to uneven feeding of your supply duct branches with just the dehumidifier operating.
Since your dehumidifier is installed in the attic, make sure that the ducting connected to it is well insulated. Also make sure that your dehumidifier cabinet is insulated. These actions will help prevent heat gain from the hot air in your attic.
Is your dehumidifier bringing in fresh air from outside? If the outside air is hot and humid, the dehumidifier will supply warmer air to your home.
Some people run their A/C fans continuously to help with the air distribution, but this is a bad idea since it increases energy usage considerably.
DryDog
Aug 06, 2010 | Aprilaire 1700 Dehumidifier
The bucket peace will not make contact inside the unit to make it run.but if i push in the plunger it will run.
This sound like the part of the bucket that makes contact with the plunger might have broken off. A simple fix can be made by duct tapping a square of duct tape to the bucket where it make a contact to the plunger.Do not duct tape the plunger this will work but most likey over flow.Hope this helps
Jul 19, 2010 | Goldstar DH504EL Dehumidifier
I have an Airforce BQDD122FW Dessicant Dehumidifier. When I bought it last year it worked OK. I have started using it again this year and although the motor appears to run normally it no longer collects...
Hi There, you have faulty heater inside. They are all the same Delonghi, meaco, Logik, ecoair .Airforce
I have done 100s now. If you good you can just twist the wire in the heater and will go again without any problems.
Its just basic steel wire twisted like a spring.
anyon eneeds help sam on 07590 057545
Oct 24, 2009 | Dehumidifiers
Running but not collecting water
your coils are probably frosted up. This can happen from the basement temperature being too cold if you dont have the automatic defrost type of dehumidifier, or it could be low on coolant from a pinhole that leaked it out. Mine did the same thing and I had to buy another one. I bought one thats operates down to 41 degrees Fahrenheit and it is an automatic defrost type. It works good for my basement because I have central air which makes the basement even cooler and harder to dehumidify without freezing the dehumidifier up.
Apr 19, 2009 | Kenmore 53701 Dehumidifier
Heat exhaust for the LG Dehumidifier LHD45ELY7
I have not resolved the issue yet.
I don't like getting into a web site, filling out a form with info and then after a click or two, find out I have to pay.
I'm sure you have experts that are very good, but I can't afford to join up with everything that run across. I'm sure it says that you have to pay on the first page, but I didn't see it.
Maybe some other time.
So, I'll just keep working at the problem until I get it.
Thanks.
Jul 25, 2008 | LG Dehumidifiers
Dehumidifiers Logo
41 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
