Question about Janome Memory Craft 5700
The feed dog switch in the back of the machine will not raise the feed dog up and down. I had to take off the needle plate because material was stuck in the mechanism, but when I put it back on the feed dog would no longer raise. It's a Janome Memory Craft 8000
  • kmapratt Jun 07, 2010
    I'm new to this and I guess there are experts in every field relative to the problem. The feed dog won't raise in my computerized machine.
    You are a genius! I've lost a day of sewing, but I'm sure I just saved at least $100 bucks. Thank you so much!
    Guru:
  • 528 Answers
Try this basic torubleshooting steps for this is a common issue for Janome Memory craft. You have to switch the dog feed back to 'up' then turn the needle wheel toward you, the feed dog should snap back into place.
Posted on Jun 07, 2010
    Scholar:
  • 130 Answers
This is showing up in the computer section. I think you would do better asking under sewing machines.
Otherwise, you may have to wait for someone who has specific knowledge of the machine.
Have you tried looking at the machine's site at: http://janome.com/
Good luck.
    I did........are there special sections for your problem.....I'm new to this
Machine was sewing ok for a short while all of a sudden it does not feed the material
Could be that you accidentally dropped the feed dogs. If the feed dogs are in the raised position and you have the stitch length set to at least #2 or higher, you should be able to see the feed dogs raise, move toward the back of the machine, then drop below the needle plate, and travel toward the front of the machine to begin the process again. If that is not happening the feed dogs have seized. If yours is an older mechanical machine, it could be that the old glue has dried and preventing the parts from moving like they should. If that is the case, your machine could benefit from a good service technician (cleaning, oiling & adjustment).
Jul 06, 2017 | Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
How do I get the sewing needle to move forward on my Janome sewing machine?
Check to see if the feed dogs are lowered. There should be a lever or switch on the front or back of the sewing arm that drops the feed dogs for free motion sewing.
Also check under the needle plate for lint build up. This can prevent the feed dogs from raising.
Feb 25, 2015 | Janome Sewing Machines
How do I get the feed dog up on model 6235
The feed dog for that machine is NOT designed to be raised or lowered; instead a cover is put over the needle plate. You might want to remove the needle plate--it's designed to be removed to access the bobbin case--and see if you can pop it up again. On models that DO have the ability to raise and lower their feed dogs, once it has been lowered, if you press the dial or lever to raise it, it won't raise until the hand wheel is turned one or two times.
Sep 29, 2014 | Singer Sewing Machines
Material won't feed through on kenmore 17600 sewing machine
Take out the material, take off the foot and needle. Stick your finger on the feed dogs and hand turn the hand wheel like sewing. Does the feed dog come slightly above the surface of the needle plate? If it does.... tighten the presser foot tension.
If it doesn't locate the switch that drops the feed dog. Make sure it's in up position.
If neither of those solutions work. Remove the needle plate and see if the feed dog or mechanism that runs it is broken
Good luck
Nov 10, 2012 | Sewing Machines
I have a Finesse sewing machine and I was sewing some placemats but it suddenly stopped feeding the material although it keeps sewing (foot moves up and down). According to the book I have checked the...
Can you see the feed dogs moving?
un thread, raise the pressure foot then manually turn the flywheel towards you and watch the feed dogs (the teeth that move under the needle plate). If they are not moving around and coming up above the needle plate then one of two things:
either you've accidentially disengaged the feed dogs, check the manual for instructions to reengage, sometimes a knob, button or slide, often on the front base or around the back of the free arm.
If they are engaged but not moving up at all, then something has gone in the drive to them, usually a gear in the free arm area. In which case, take to the shop for repair.
Jul 01, 2011 | Sewing Machines
My material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Oct 17, 2009 | Sewing Machines
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Nov 29, 2008 | Baby Lock Esante
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Sewing Machines Logo
173 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
