Question about Toys
How long do i charge a 6 volt Peg Perego battery
I recently picked up a John Deere riding toy at a garage sale and I need to know how long do i charge a 6 volt Peg Perego battery for?
SOURCE: PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Posted on Oct 17, 2008
momsjustknow
  • 135 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
bozcro
  • 867 Answers
SOURCE: where to buy a replacement battery
take the battery out and get some specs. then search the internet for prices, i have found many rare batteries this way. it might be a common battery that you could buy at most stores, so pop it out and have a look
Posted on Jun 14, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
qpoint
  • 69 Answers
SOURCE: We live in Australia and
Presumably, the John Deere is manufactured in or for the USA. If so the plug for the power adapter is for USA. To confirm this check for 2 straight vertical pins adjacent to each other at the top of the plug. The plug may or may not also have a circular round (or half round) pin centralised underneath the two vertical pins. Also confirm that the power adapter has printed on it something similar to 100 -- 120V (volts) to 6V. In this case, you will need a plug-in transformer to operate the power pack. The voltage required is: 240V input to 115V output. You should be able to purchase an enclosed unit with the appropriate plug (for AUS) and socket (for US) from Tandy, **** Smith or a similar retailer or an electrical wholesaler. The other specification you will need when purchasing an enclosed transformer is the power rating in Watts or VA. Look for this information on the power pack and buy a transformer that is rated above this rating. If the power rating is not stated on the power pack look for a current rating in amps (A) or milliamps (mA -- 1 mA = 0.001A) associated with the US voltage (100 -- 120V). Multiply the current x the voltage to obtain a VA or Watts rating. Buy a transformer which is rated above this power rating.
Posted on Mar 05, 2010
Testimonial: "Thanks for the prompt answer! I'll have to wait until I visit town again to see what I can purchase so the grandkids are kept happy!"
Someone gave me a Peg Perego John Deere Gator that needed a new battery.
check the battery with a multimeter and make sure that it is putting out at least 12 volts
Mar 20, 2013 | Peg Perego John Deere Gator HPX Ride on...
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Battery connectors get hot on gator
are both wheels turning in all of the gears?
May 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
I havent used by feber car for 5yers n i lost the adaptor to charge it so if i get a new gharger will it be fine to use it or should i remove the battrey n re-charge the battery? n where can i get the...
KidsWheels features a full line of Kids battery powered electric ride on vehicles, cars, pocket bikes, Kids battery powered electric toy cars, Kids cars, Kids ride on trucks, Kids ride toy Quads, Pedal Cars, Big Toy Ride Ons, Big Wheel, Jeeps, Peg Perego Battery Powered John Deere Gator, Honda Minimoto, Winther Tricycles, Peg Perego Vespa, Peg Perego battery powered John Deere Worksite Gator, Peg Perego Gaucho Super Power S Series, Peg Perego Gaucho Super Power S Series, Peg Perego Ranger RZR, Orange County Choppers, Power Wheels Ninja, Peg Perego Gaucho 4.0, Lightning PAC, Power Wheels MX3, Peg Perego John Deere Power Lift Gator, peg Perego Polaris 800 Twin, Power Wheels Nascar Ride On Jeff Gordon L7822, and more..
KidsWheels Ride On Toy Store
519 North Bell Blvd.
Cedar Park, TX 78613
800-396-9680 512-257-2399 Fax 512-257-0093
Store Hours:
10AM - 5 PM CST Monday - Friday
10AM - 4PM CST Saturday
Closed on Sunday
http://www.kidswheels.combenluis_1.jpgbenluis_0.jpg
Jan 17, 2011 | Toys
HI, I HAVE A PEG PEREGO JOHN DEERE LOADER.I NEED A
You can get compatible replacement batteries for your ride-on toy from here.
John Deere Ground Loader Peg Perego Ride On Toy Battery 12 12 AH F2... You can just change the battery and use the plastic casing and wires attached to your current battery. This will save you a nice sum of money. It is not hard to do. Check this video to see how to do it.
Oct 03, 2010 | Peg Perego 12 Volt Rechargeable Battery
John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Jun 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
181 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
