Question about LG Refrigerators
I have an LG refrigerator model number LRTPC1831T and it is leaking water from the inside of the refrigerator. I think it is coming out of the top and running down the back and out of the bottom. I do not have any water lines hooked up
  • Paul Falzarano Jun 09, 2010
    I would like to thank you for thwe web you sent me! It really helped me understand what could have been wrong with my frig. I hope I fixed it. Only time will tell but thanks for now!
    Brigadier General:
  • 3,513 Answers
Please check the bellow link to diagnose the leakage of your refrigerator…
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 07, 2010
  • Paul Falzarano Jun 07, 2010
    There is a small hole in the back toward the bottom that I think the water is coming from. The post that you sent me sounds like there is a clog in the drain for the defrost cycle that goes to the bottom of the pan. how would I trace the drain line from start to finish?
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Ireland
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 17, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Kenmore Refrig
It appears the defrost drain inside freezer is blocked or the drain tube leading to pan near compressor is clogged I would unplug refrigerator and remove the back panel in freezer to examine the drain and get back with me to let me know what you find, also get model number for your refrigerator so I can help you better. Sea Breeze Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 27, 2009 | Refrigerators
Fridge leaks water on the inside, is not condensation
Hi!!! Your drain line is plugg, also there might be some dirt plugged so remove the evaporator panel are clean the drain line..deb5a30.jpg
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water Leaking
The defrost drain is clogged up. I can't say much more because you didn't supply the model #
This may be a drip catch that you can get to from inside the refer or it may be the big tube on the backside of the box.
You may have to take the freezer apart and use a hair dryer to thaw out the ice.
Model numbers are important!
Jan 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Re: Lg Lrtpc1831t
Shirlee, you might not have the refer leveled right. The doors should close by themselves when released. Have someone bring the front levelers down so it is pitched back a little. This should eliminate the freezer door staying open. This is caused by the rush of air from the lower compartment to the upper compartment during closing.
Nov 03, 2006 | LG LRTN19314 Titanium Top Freezer...
Refrigerators Logo
140 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
