Question about Cameras
Why does my camera only video for 15 seconds? I know it's supposed to video until I want it to stop.
    Brigadier General:
  • 11,967 Answers
You're not giving us much to work with. What kind of camera...what kind of card...is it a class 4 or better.
Posted on Jun 07, 2010
My fuji f770exr is taking about 10-15 seconds to turn on - supposed to take 1.5 seconds - what can I do?
Look on their website for tech support Ph. # and ask. My best guess is that they will need to lay their hands on it.
Aug 13, 2014 | Fujifilm Finepix F770exr 16 Megapixel 3d...
Power turns off after about 10 secs of watching the video
First guess is the camera has dirty heads. Suggestion is to run a head cleaner in your video camera. Regardless of the instructions on the head cleaner, I usually run the head-cleaner tape on "Play" for about 10 to 15 seconds, and then on "Record" another 10 to 15 seconds. Wait for 10 minutes before loading your playback tape. Try playing your tape again.
Also, check to be sure the tape is loaded properly and that the hatch closes securely and properly. A hastily loaded tape or an ill-fitting closure could cause the play function to stop.
If this does not solve the issue, it may be something in the play switch or in the playback mechanism that requires repair services. If the problem continues, I would recommend calling the Panasonic Company and speak with Tech support or Video Camera Repair. They may be able to tell you and estimate of what it would cost for the repair.
May 16, 2011 | Panasonic NV-DS60 Mini DV Digital...
How i take photo in night ! my problem is for clearity
I have a sample image here, I'm not sure how it will load it's a crop from a full frame.
I've read into your camera specifications and have found that 15 seconds is the longest shutter speed you can use, I didn't find a "Bulb" for shutter speed and this will limit your abilities to make clear "clarity" night photographs to work within the 15 seconds you will need to increase the ISO, increasing the ISO will introduce a grain effect and the clarity will fall off.
I'll give you a starting point some things you won't like what I'm saying but I've been doing this since 1983. You will need a sturdy tripod. Shut the IS off. See if you can focus on your subject and compose. If you can't auto focus (lack of light or contrast) switch to manual focus, focus is critical if you can't obtain this the shot will be useless. After focus compose your scene set your camera at ISO 100, manual mode F11 adjust the shutter speed to give proper exposure increase ISO by one stop and decrease F stop by one (F8) check exposure once you have the exposure recompose your scene. Make sure the camera is in manual focus, IS (image stabilization) is off, set self timer to 2 second delay, check your scene again and release the shutter and don't touch the camera again until the exposure is complete. There is a whole lot more to this and you are limited because of the lack of the bulb feature or a shutter speed greater then 15 seconds.
Sample image
Jan 07, 2011 | Canon PowerShot SX30 IS Digital Camera
Metz 15 MS1 Macro Ring Flash with Panasonic Lumix G1 4/3rd Camera
Set camera to manual exposure. Set Shutter below 60 Set F Stop until exposure is correct.
atdlee@netzero.com
Feb 08, 2010 | Metz 15 MS1 DIGITAL MACROFLASH TTL Ring...
Video recording shuts down after 15 seconds
I just looked at my Sony DCR-TRV30. Not the same, but perhaps similar. My camera records lengthy videos on tape and only brief videos on memory stick. I suggest that you stick to tape for video.
Good Luck
almarc13
Feb 12, 2009 | Sony Handycam DCR-TRV730 Digital Camcorder
Video Stops Early
http://www.microsoft.com/hardware/digitalcommunication/productdetails.aspx?pid=007.Everything you need is here.this is a solution.when you vote if this worked vote blue ty.RICHARDM69
Dec 15, 2008 | Microsoft LifeCam VX-3000 Web Camera
Can't turn on my camera!
Hi..
I have a link and some information I found on the video option to your camera. This link is for the manual located on hp.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=371583&lang=en&cc=us&lc=en&dlc=en&
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
NOTE
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Feb 27, 2008 | HP Photosmart R707 Digital Camera
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
