Question about Samsung 7.3 Cu. Ft. Electric Dryer
Dryer has no heat it works it turns u press start but there is no heat coming out
  • Samsung Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer has no heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is ..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gifDryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 08, 2010
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Hello
You are sure the element heats up? Belt around drum tight? Drive motor getting power from relay
Mar 09, 2010 | Kenmore 63942 Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer turns on. no heat and timer does not advance?
sounds like glow bar or photo sensor not working properly. should be access panel to veiw ignition system, if glow bar turns white hot when dryer is started, try to clean face of photo senser and re-start. unplug dryer before cleaning sensor. timer will not start until dryer comes up to temp.
May 15, 2009 | Maytag SDG4606A Gas Dryer
DRYER SHUTS OFF PRESS BUTTON COMES BACK ON
Hard to answer as I cannot see diagram for the dryer. First off would check the door switch as it could be opening contacts due to vibration. Second could be Hi heat thermostat taking dryer out and after it cools will restart with touching of the start switch. To find if it is Hi heat thermostat, turn dryer on, when it stops open door and see if it is extremely hot inside. If so your control thermostat is probably not working correctly and your last safety thermostat is stopping the dryer. This could be a very unsafe condition as the lint etc. in dryer could catch on fire.
Mar 28, 2009 | Whirlpool LER4634J Electric Dryer
Dryer is running but it's not hot
If the electronic start is not working, it may need to be replaced. Call an appliance parts store and ask some specific questions to them about how you can test that component and if they carry a replacement for your specific make and model. Good Luck!
Jul 05, 2008 | Whirlpool LGR7646E Dryer
80 series front load dryer will not turn.
It almost has to be the belt as the heating element won't come on without the motor turning.
Jun 26, 2008 | Kenmore 62802 Electric Dryer
Samsung 7.3 Cu. Ft. Electric Dryer Logo
182 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
