Question about KitchenAid KSU90S0MLL 16" Undermount Stainless Steel Sink
Water is dripping out of the bottom of my kitchenaid kadette 250 1/2 HP disposal. Is there a fix?
  • 2,841 Answers
If the leak is coming from the bottom of the disposal check the sink connection, drain connection, and housing gasket. If you find these are all good and you can see the water is definitely coming from the disposal itself and not from any of these connections, then the internal seal in the disposal is bad and will need to be replaced. If the disposal is over a few years old then it is more than likely best to just replace the unit. Not cost effective to have it repaired.
Posted on Jun 07, 2010
Kitchen aid kadette 250
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Jul 05, 2013 | Garbage Disposals
KUDS35FXss is dripping from the bottom of the door
Bad door seal drain plug not knocked out of garbage disposal other would be main seal at pump u can take bottom dishwasher off and watch were coming from if it's at door then door seal if still has water when done then check drain and disposal drain plug hope this helps
Feb 21, 2013 | KitchenAid 24 In. Stainless Steel...
WATER DRIPPING OUT OF BOTTOM OF UNIT, WHAT'S UP?
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
e
Sep 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kitchenaid kadette 250 1/2 hp won't turn on.
Try turning off the circuit breaker and turning it back on, pushing the reset button firmly on the bottom of the disposer, and checking to make sure it's not jammed and rotates freely. If it is jammed you can put a disposer wrench or allen wrench in the hole in the bottom and rotate the shaft to free it. There might already be a wrench under your sink for that.
Oct 23, 2009 | KitchenAid Home
Removing knockout from KitchenAid Kadette 250 disposer
Hi, You need to punch out the plug from the outside. The plug will fall into the disposal and you can reach in to remove it.
I use a small screw driver and punch through the plug in a few spots to weaken the plug. This will allow the plug to release easier.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Aug 02, 2009 | Dishwashers
Garbage disposal won't turn on
Three points to ck. !) make sure disposer is plugged in under ther the sink. 2) Make sure the circuit breaker at the breaker panel has not tripped. 3) Make sure disposal is off and make sure it is not jammed, 3) Press reset breaker located on bottom of unit (red button.) Then try wall switch again.
May 20, 2009 | KitchenAid KSU90S0MLL 16" Undermount...
Black water came urping up when I cleaned my disposal with ice
you need to be careful you may be getting close to clogging your sink thats really the only time you would get a backwash from a disposal
Apr 07, 2009 | KitchenAid Home
Kitchenaid Kadette hums and does not run
Mine does this when it is clogged, one time my daughter cleaned out the fish take and filled the disposal with pebbles. You should have recieved an Allen wrench with the unit. You will be able to put the Allen wrench in the bottom of the unit and turn the disposal manualy, this should break loose any jammed blades.
Apr 02, 2009 | Kitchen Appliances - Others
I am attempting to install a dishwasher drain line to a kitchenaid disposal under my sink. The disposal is a Kadette 250 1/2 hp. There is some kind of block or plug stoping the water from entering the...
Remove the hose from the disposal, take a hammer and long screw driver, put it in the hole where the hose attaches and knock the plug out. Turn power off to the disposer and pull the plug out of the disposer. Hope this helps.
Aug 09, 2008 | KitchenAid Dishwashers
KitchenAid KSU90S0MLL 16" Undermount Stainless Steel Sink Logo
1,289 people viewed this question
Top KitchenAid Home Experts
john h
Tom Chichester
Are you a KitchenAid Home Expert? Answer questions, earn points and help others
