Question about Imer Tile Saw Combi 200va Portable Tile Saw With Stand
Saw will not cut straight and destroys blades 250
I had the same problem. If you are cutting porcelain tile, it will not cut straight. The motor isn't fast enough.
These saws are made for stone cutting.
Posted on Jul 16, 2010
What would cause the ridgid 10inch wet saw blade to not cut straight?
damaged teeth on one side not cutting evenly so the good teeth on the other side allows the blade to veer away from a straight cut
Have the blade resharpened
Feb 17, 2016 | Blade Saws
Saw is not cutting straight
Make sure the miter is lined up at 90 degrees to the blade. The fence has to be parallel to the blade and the blade tight. Cuts should be straight if the piece is held firmly and you move at the proper speed. Good luck!
Mar 05, 2011 | Dewalt D24000S Wet Saw With Stand
Saw is not cutting true / will not cut a straight line ?
Check blade is on properly. Remove blade and clean area where mounts to shaft. Make sure proper washers are in place. If blade is bent or wobbles replace. If blade is dull replace. Be sure you're getting enough water to saw. Don't force the tile through, let the saw do the work. Nothing helps any kind of saw more than a nice new blade.
Jul 01, 2010 | Diamond Products Mk - 101 10" Tile Saw
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 | Saws
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
Cutting straight
The tension on the blade. the position of the guide rollers, and the condition of the blade are all important to get a straight cut. You might want to try lowering the guide rollers down close to the wood being cut. good luck.
Apr 26, 2009 | Ryobi 9 in. Benchtop Band Saw
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Mar 06, 2009 | Jet 414458 HVBS - 56M Horizontal/Vertical...
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Imer Tile Saw Combi 200va Portable Tile Saw With Stand Logo
351 people viewed this question
Top Imer Saws Experts
Tom Chichester
ray gallant
Are you an Imer Saw Expert? Answer questions, earn points and help others
