Question about Amana NDE2330AY Electric Dryer
Dryer runs but no heat
The dryer runs and now it keeps needing to run more cycles to dry clothes, today no heat at all
  • 10,319 Answers
Lean the exhaust vent tubes thoroughly and try again to heat up
a sensor in your dryer will shut down the heat if lint build up is present
Posted on Jun 07, 2010
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Dryers
Dryer will not turn off
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Amana NDE2330AY Electric Dryer Logo
352 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
