Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Just got whirlpool cabrio top loader slighty used yesterday. It did'nt come with a manual. The first load ran great but as I started the second dl popped up. I know it's because the lid wont lock but I have no clue how to fix it. You can hear it trying to lock but I dont know why it wont connect all the way. Please help! Oh and by the way I looked up the code list and saw test number 8 for the lid lock problem but the instructions were very unclear to me and step one tells you to run some kinda manual something lid lock test but does not tell you how to run it or where to look to find out how! UGH!!! I am so frustrated please help!!!
  • honeymokey
    honeymokey Jul 11, 2010
    Cabrio has many problems.
I have a WTW5600XW Cabrio Electric Dryer and a WTW5640XW Top load Washer. I have lost my ring and think it may be in either one of these. I think I forgot it in my pants pocket when I put it in ther
In the washer it could be under the agitator if it is a top loader, if it is a front loader there is really no place for it to go but check the rubber seal around the door. In the dryer it should be in the tumbler or possibly in the lint filter but unless the lint screen is broken or you ran it without one it should not be able to go out into the venting piping etc
Sep 19, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Unballenced on spin even when empty
It may come up an unbalanced load but it may a sensor that is on recall. I have a Whirlpool Cabrio top loader and after I start it it says F1 which is a sensor on recall and I have to restart it several times before it continues the load. Go to their web site and you can look up the exact model to see if yours has a recall as well.
Sep 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting a DL on the top load washer
The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DL indicates a problem with the door lock mechanism. See the section on troubleshooting and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirpool cabrio top load washer 1.5yrs old flashes FXX error code
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  4. Switch on the power
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared.
Dec 10, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio
that is a suds detection error code try not using so much detergent then see what happens
Mar 24, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
204 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
