I have replaced the hard drive in my Pioneer dvr-rt601 because the old drive failed i got the new drive from a Pioneer recomended dealer and now i can't use hard drive i just HDD ERR how can i resolve this problem.
  • 2 more comments
  • smokingman Apr 10, 2008
    I have got it all connected right and have used the firmware from Pioneer download but it will not allow me to access hard drive to record. I only have access to VHS or DVD as machine starts up showing HDD ERR then defaults to DVD
    Thanks so far have checked hard disk is set to master but formatting HD is going to be where the real problems start as i can not get service manual for DVR-RT601H as no one appears to have one (that includes Pioneer UK who say they only supply to their recognised service centres). Hope you might have a trick up your sleeve keeping my fingers crossed.
  • smokingman Apr 11, 2008
    Still no joy on getting a service manual and apart from taking it to a service centre no one seems to be able to help all seem to think it's down to the CPRM and the need for a service remote. Have you any ideas.
    Thanks you have given a few angles to look at, as for going to Pioneer service people to get them to finish the job they won't do it any cheaper than if they had done the whole job (had already asked). Will let you know how i get on again thanks.
  • 19,396 Answers
You need to check that the hdd isconnected properly
Posted on Apr 10, 2008
  • 3 more comments
  • Ginko
    Ginko Apr 10, 2008
    It is normal getting an error message if the hd is new
    You need to check that the hdd is well connected to the cable inside your dvd. Check also that the pin bridge at the back of your new hard disk is not set as slave. It think it should be set as master/stand alone. Eventually try both master options. When you ensure everything above is ok, you will need to format and write image into your HD. Not many DVD device like yours do this automatically, usually you have to access a service menu and restore the hdd image.
    You need to get the service manual, which will display the whole procedure. You can request and buy it from pioneer for about $25, or try downloading free version from this website here.
    The download is a bit tricky, but at the end it will work. You will need WinRAR to unpack the manual, and will need to download all files, as it is a split-up.
  • Ginko
    Ginko Apr 10, 2008
    If it still does not work, post again on this thread. I will able to assist you further within 24 hours, busy with customers now.
  • Ginko
    Ginko Apr 11, 2008
    Pioneer service manual are not easy to find.I do not have the service manual for rt601.
    Here uploaded for you to dowload the manual for 620 and 720 models, which are not very different from your device.
    In the last couple of page is descripted a service reset procedure , which is the one supposed to restore hard drive settings. It is likely that works the same on your model, usually service procedure are same for same range of models.
  • Ginko
    Ginko Apr 11, 2008
    This company programmes Pioneer service remote and service disk. You need to contact them and explain your specific problem, so that they can send you the proper product.
    Pioneer, as many other company does its best to prevent users from serviceing their products, mainly for safety reasons.
    If you have to buy the remote for additional $20/$50, you may consider asking a service to finish the job you started. If you already installed the HDD correctly, and the serviceman does not even need to open your device, it may be done for a modest fee. Find a reliable and hones service in your area and get the job done for $50/$80, that is my suggestion.
    Regards
  • Ginko
    Ginko Apr 11, 2008
    Sorry I forgot the link for piooner remote programmers, here you go.
    Keep in mind that this are not original Pioneer service remotes, are hacked remotes customized to execute only required operation. They should be able to provide you a remote or a disk to reinstall your HDD image, but I cannot guarantee it works. Only pioner distributes original service remotes and service manuals.
    Regards
Hi.. please help i have a pioneer hard drive dvr-520H. i love it and have never had any problems over the years. but just yesterday it froze up on me when i was trying to watch a recorded show. now when i...
That sounds to me like the hard drive has crashed and it can't find the required "hand shake" from the drive, hence taking such a long time to initialise and then showing rubbish. Unfortunately fitting a new hard drive to most of these machines requires matching hardware to firmware and that is achieved with the use of a "Service Remote". So fitting a replacement drive may not fix it without matching the new drive with the special remote.
If you have a Pioneer Dealer in your area, get them to estimate the repair and weigh it against the cost of a replacement.
Hope that helps.
Mar 11, 2011 | Pioneer Televison & Video
Pioneer DVR-112D refuses to read CDs?
This unit has alot of issue with CD reading and writing probably its a problem with the lens of this player, so since its still new better take it to the store and have it replace..
Hope that helps........
Aug 10, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer DVR-5100H : CPRM error after changing DVD drive
I've never fiddled with this dvr but i belive there is a service cd you can download if you search around. Not sure it will help but i guess it's a start.
Apr 11, 2009 | Pioneer DVR-5100H DVD Recorder
Pioneer DVR-1910LS will not eject drawer
the drive mechanism might have failed try to contact pioneer people !
OR if it is NOT in any WARRANTY then try to open the drive up !!!!!
Jan 31, 2009 | Pioneer DVR-107D DVD±RW Burner
Picture freezes intermittently and permanently on Pioneer DVR
Sounds like an internel hardware problem on your hard drive call the company who makes the unit its not that old and they still may fix it free
Dec 07, 2008 | Televison & Video
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Notice+Regarding+CD+Read+and+Write+Functionality+in+Certain+Pioneer+Computer+Drive+Models
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvd-rw dvr-
have you connected the 4 pin molex plug from the computer mainboard to the drive ?
is the IDE Cable correctly fitted ?
did you set the jumper connector on the rear of the drive to Master Or Slave ? if you are sharing the cable with a hard-drive, and the hard-drive jumper is set to slave, then the dvd will have to be set As Master ( otherwise they conflict ) or only 1 device will be recognised.
This should Solve your problem here.
Mike @ Compurepair.
Feb 19, 2008 | Pioneer DVR-112D Burner
Pioneer DVR-111d dvd rw
Is this a new drive? If so, make sure that the media is put "label side up". You have a bad drive if this is not the case...accordianman
Nov 25, 2007 | Pioneer 16X DVD Drive Burner (Model...
Dvr-106d -Windows freezes,cant read new Dvds
if you have had two drives with the same problem i would check the ide cable and swap to another one if you have a master and slave twin connector ide cable, or even try the dvd rom on the same ide cable as the hard drive as you know that that ide connector and cable is working, unless you have a SATA hard drive in which case you won't be able to; but will still have a spare ide channel connector to try the drive on.
Jun 26, 2007 | Pioneer (DVR-106D) DVD±RW Burner
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
