My sony kp65ws510 has bouble vision pink eyes on top and green on bottom and is arched
  • 505 Answers
Convergence
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
let me know if you need further assistance.
Posted on Jun 07, 2010
American camper tent 2455 setup
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Apr 09, 2013 | Sport & Outdoor - Others
Apr 09, 2013 | MSR Family Tents
Instruction for setup of American Camper tent 8x11
Aug 28, 2012 | MSR Kamp Rite Double Tent Cot
I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT IF ANYBODY CAN HELP ME ON MY SEARCH TO FIND SOME INSTRUCTION
Jul 12, 2010 | MSR Family Tents
GREEN AND PINK COLORS ARE SEPERATED PICTURE IS ARCHED TOP AND BOTTOM. HOW DO I REPAIR THIS??
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 09, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
There is a arch at the bottom going to the left
Covergence needs to be fixed replace Both of your ICs they are big black ICs with STK on them for example STK392-110 if this the # on yours use 180s better ics.For parts Call 1-800-223-3205 www.electronix.com.
Dec 26, 2008 | Toshiba 57H82 57" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Pictures are apearing in greens and pink
if you dropped it drop it again, thats what i did. i cant believed it work. fight fire with stupidity. drop it from the same altitude.
May 29, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
