Question about Dell Inspiron XPS M140 Notebook
The screen doesn't show. when you first turn it
The screen doesn't show. when you first turn it on or open the lid is flashes for a second or two and than goes blank.
    Sergeant:
  • 356 Answers
Hi. Just reseat the memory. There's a panel that can be opened at the bottom of the notebook. Use a Philips Screw to open it then remove and reseat the memory module.
If it still doesn't solve the issue, it's the motherboard that needs replacement.
Posted on Jun 07, 2010
Not spinning or rinsing
see this possibles causes:
t doesn't pump or spin
frozen puller+ lid switch defective
It pumps, but doesn't spin
lid switch defective test, or motor coupler replace
It spins only with the lid closed
this is safety, the spin only with lid closed, tested
see the diagram . God bless you
May 16, 2012 | Washing Machines
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
When I went to shut it down it had a few programs to shut down. I waited a few minutes then closed the lid down. It is now flashing on the first light symbol on the corner and when you open it up it turns...
Sounds like it is stuck in hibernate mode. Hold the power button down for 5 seconds and try to start it again. If it doesn't start remove the battery, unplug the laptop, hold the power button down for 60 seconds. Now plug in the power supply but leave the battery out. Turn it on. It should start now and you can re-insert the battery.
Apr 22, 2011 | Compaq Presario CQ60-212US Notebook
Hi my hp printer keeps say 3 on the screen and it says it out of ink but on the computer it shows us that we have enough please can you help thank you from Natasha.
Try unplugging the printer power from the wall for a good 90 seconds. Then replug it in. If it still shows needing new ink, try opening the cover to the printer, removing the current ink cartridge, then shutting the lid. Turn off the printer from the power cord again. Then plug it back in, turn it on, re-open the lid, and put back in the same ink cartridge. If it still has the problem and you are sure there is enough ink in the cartridge it sounds like the printer sensor has an issue.
Sep 09, 2010 | HP DeskJet F380 All-In-One Printer
The washer is stuck locked. When turned on it shows OP where the minutes are!! PLEASE HELP !!
Don’t force the lid open and break the lid locks.
Here is the Service Manual and parts look up;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Use this procedure for releasing the washer top from the base;
Un plug the 120VAC power cord to the washer.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
This will get the clothes out.
With the washer top raised gently push to Left and Right lid lock latches to outside of the lid the unlock position.
You can now lower the washer top to the base.
Do you want to DIY the OP error code?
The OP error code could be caused by a Lid Magnet out of position. To do a quick check with the lid open power up the washer. Do you have the OP error code showing? If so take a large magnet and place it over the grey left lid bumper and see if the OP error code will clear the LED display. A Pic for reference;
If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
e830e40.jpg If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Light flashes 6 times locked rotor
Try to turn the center pulley if it moves freely then unplug machine for 30 seconds then plug it back in then open and close lid 5 times within 10 seconds after plugging in. If the motor resets back to 1 flash every second then you will probably be able to operate machine. If it does not reset or it fails again the motor needs replaced.
Feb 26, 2010 | Washing Machines
Philips 3258
1. With the remote control, turn on the player. Keep the tray closed.
2. Press SETUP and use the buttons LEFT or RIGHT (arrows) to go to the Preferences Page.
3. Type 138931 and a screen will appear on TV.
4. Use the buttons UP/DOWN (arrows) to change the region code to 0 (zero), then press OK.
5. Turn off the player and turn on again.
OR
open lid; slowly press 9,9,9,9, then 0. will show region 0 on screen for maybe 2 seconds , shut lid & you are done!
One of these 2 should work. If one does post back which one please.
Sep 08, 2008 | Televison & Video
Printer is on but cannot print
if your power light is off and the paper and ink lights are flashing try this.
1. remove all the paper,
2. open the cover and check for paper jam
3. make sure the ink cartridge lid is securley in place by opening and re closing the ink cartridge lid
reclose the lid, disconnect the power supply and hold the power button for 30 seconds. reinstall the power plug and turn the printer back on.
hope this helps
May 12, 2008 | Epson Stylus® Photo R2400 InkJet Printer
Dell Inspiron XPS M140 Notebook Logo
141 people viewed this question
Alun Cox
