My daughter brought her tv home from college and it seems like verizon fios which we have does not hook into the tv, it does not use a coaxil cable? she did something and tv got stuck on channel 61 and all other channels were snow...
if you go to your cmd prompt and type in ipconfig /all and see what your ip address is...if it starts with 169 type ipconfig /release then press enter then type ipconfig /renew and check your ip address again...it should start with 192
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Make sure the TV is set to output audio to the digital optical port. Then make sure you have selected the proper output mode on the home theatre. Unplug the optical cable from the back of the home theatre and see if the red laser is on (don't shine it in your eyes! :))
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
