Question about Motorola Mobility H700 Wireless Headset
Change battery on a motorola bluetooth H700 - Motorola Mobility H700 Wireless Headset
  • 3 Answers
Turn off the unit before attempting a battery replacement. Without doing so, the power disruption that the headset will acquire can damage the internal workings.
  • Find the even **** on the bottom side of the unit, where the microphone boom is attached.
  • Place the edge of a flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up, however.
  • Find the small ring near the plug and the mini-USB port. Use the screwdriver to push under the ring where the battery is found. Push forward gently to pop the battery out.
  • Posted on Jun 07, 2010
    How to use my H700 after charging ?
    If tv is bluetooth capable, look under menus and pair with H700.
    Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
    Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
    My motorola h700 won't turn purple to connect to my motorola i576
    Make sure the battery is good in your H700.Make sure your Bluetooth is enabled on your i576. To do this, go to Contacts>More>Bluetooth>Setup>Power> then select On. Back up one level and select Link To Devices. If everything is correct, they will find each other.
    Dec 20, 2009 | Motorola Mobility H700 Wireless Headset
    Pass key
    h700 passcode is always 0000 4x the zeros unless it has been changed by a previous user then it is impossible to guess what it has been changed to. This was sourced directly from www.motorola.com
    May 04, 2009 | Motorola Mobility H700 Wireless Headset
    Motorola H700 with motorola i880
    The passkey for the Moto H700 is 0000, four zeros.
    Mar 21, 2009 | Motorola Mobility H700 Wireless Headset
    Broke the ear hook for the Motorola h500 bluetooth headset
    I searched on google for motorola h700 and found plenty of sources? Amazon.com and others.
    Aug 30, 2008 | Motorola Mobility H700 Wireless Headset
    I can't pair my Motorola H700 to my Blackberry curve.
    http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
    this actually works.
    Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
    Problem with Motorola H700 Bluetooth
    rhondarenee: If you're using a Motorola RAZR V3, the problem is the cell phone. Also check the volume buttons on H700 that sometimes it goes the volume all the way down. It is a common unnoticed situation. SithPitt
    Jul 04, 2007 | Motorola Mobility H700 Wireless Headset
    Motorola Mobility H700 Wireless Headset Logo
    722 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Lawrence Oravetz
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
