Question about Water Heaters
AO Smith Burner Issues
Good evening,
I have an AO Smith GPVH 50 that is approximately 18 months old. Just this evening, it decided to stop heating. I followed the shut-down/restart process (waiting 5 mintues) and the electric probe glows bright orange and the burner initially lights. But, 15-20 seconds after the burner lights the system shuts down again. The system keeps trying to restart but the burner will not stay lit. Any thoughts...Brett
  • 34 Answers
This system uses an electrical test to make sure that the burner is lit. The flame sensor will either be broken or will be covered in deposits (clean with an emery cloth).
The flame sensor is usually a small metal rod that would be in the direct line of fire of the burner with 1 wire attached.
CAUTION:
The ignitors can be very fragile and are expensive. They are very brittle, do not touch it.
Posted on Jun 07, 2010
Hot water heater
You need to change the elements out
Oct 01, 2016 | A.O. Smith GPVH-50 Residential Water...
No hot water - the light shows red. It has had problem in the past months but cutting the power off and back on seemed to reboot the computer. This time the light stays red.
Before calling service technician:
Click following link, the click product, then scroll to page bottom to tab that offers technical literature, and download service manual and operation manual.
http://www.hotwater.com/water-heaters/residential/hybrid/
Read the required installation and maintenance protocol to see if air filter has been cleaned regularly, or the condenser coil might be dirty.
Required maintenance can be done by service tech recommended by AO Smith.
Contact AO Smith to find trained person, and next time, do not install expensive water heater since all savings disappear with service issues.
Gene
h
Sep 08, 2013 | AO Smith PHPT-60 60 Gallon Voltex...
Where can i get a 21dv50 water heater to buy
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 17, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
AO Smith Water heater FPSH50-260 keeps blowing fuses
FPSH series is a power vented residential gas water heater.
1) The blower is plugged into 120Volt outlet. If blower has short, then it will trip breaker.
Blower could be Fasco model 7021-10195, or 7021-10770. Call AO Smith: 1-800-527-1953. They will need model number and serial number located on label on side of tank.
2) Before calling AO Smith, check outlet with circuit analyzer. Outlet must have correct polarity and must be grounded. Unplug cord to water heater and run continuity test from ground prong on electrical plug to manifold tube on gas valve.
3) Also if a fluorescent light fixture is on the same breaker, that can cause burner to short cycle.
4) Connect water heater to different outlet and see if problem continues.
5) AO SmIth has service manuals for the FPSH series that download to your computer:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Sep 20, 2011 | Water Heaters
I have a GPVH 40 100 AO smith hot water heater.The FV (flammable vapor) sensor has been setoff from us painting the floor yesterday. How do I reset the unit?
AO smith manuals
http://www.hotwater.com/lit/im/r-gas.html
GPVH series manual
http://www.hotwater.com/lit/im/res_gas/315465-000.pdf
You can search the manual for FV
The FV sensor shorted because it detected flammable gas
Quote manual:
Flammable liquids (such as
gasoline, solvents, propane (LP or butane, etc.) and other substances
(such as adhesives, etc.) emit flammable vapors which can be ignited
by a gas water heater's hot surface igniter or main burner. The
resulting flashback and fire can cause death or serious burns to anyone
in the area. This water is equipped with a FV sensor for detecting the
presence of flammable vapors, see Figure 3. When the sensor detects
those vapors, the unit will shut down and not operate. Should this
happen, please refer to the troubleshooting guide on pages 28-30.
Troubleshoot step 14-15 says
replace the FV sensor
call tech assistance number that shows on water heater
AO Smith will refer you to a plumber
I don't believe homeowner can buy these parts due to Federal regulations
The shorted FV sensor probably saved you a flash-over
The cost of 2nd degree burns from a flash-over would be astronomical.
Fortunately you're ok, and the other folk in the room are ok.
In the old days.
Two guys I knew, winter 1978 Chicago, were laying VA tile using the black mastic.
They were killed and the house burned down because of the water heater.
Main office marked the event with a memo saying they still owed money on their account.
The only company with a re-settable FVIR that I'm aware right now is Bradford White
http://www.thetankatwaterheaterrescue.com/forums/forum3/2679.html
http://411plumb.com/bradford-white-defender-water-heater-review
Bradford White Defender FVIR is resettable without buying parts.
Oct 24, 2010 | Water Heaters
Burner didn't ignite on my AO Smith model FXGT/PGXT
Unless your AO is a high recover it will take a while for it to fill up with the water that you have used then reheat the water in the tank.
Nov 12, 2008 | Water Heaters
Water Heaters Logo
341 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
