Question about LG 42PX3DCV 42 in. Plasma EDTV
It will not turn on. At first when it wouldn't turn on, unpluging it for a while would alow it to start up, but now, it just won't start, there is a 'click' but then nothing.
  • janinparadis Jun 09, 2010
    tv not, coming on open and check for podsible solution,relay seems to be turning of because of voltage problem cause by unit (powr bord)
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.These kind of issues in plasma usually happens due to bad cap on any of the boards inside. However, to check what has gone bad you’ll have to open the back of the unit
you’ll need to check bulged/swollen capacitors on power supply board. As the unit won’t show anything for a long time so it means that it is the power board which is causing this issue. These issues usually happens due to overheating in plasma TVs after sometime, as these sets are very hard working device and produces a lot of heat. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 09, 2010
  • 11,896 Answers
Either there is a bad relay, or a bad power supply. The relay if there is one on this model, would be on the power board. Trace the wires from plug-in cord to power board. Test the power with a voltmeter. There should be a label on teh tv set that states the DC Voltage Output. The number should match.
Posted on Jun 07, 2010
  • Nate Stansfield
    Nate Stansfield Jun 09, 2010
    I would recommend testing the power board and test power supply if it is seperate from power board. If they are seperate, find which one isn't putting out the correct amount of power. There should be a label on the set that states the DC Voltage Output. Replace either the power board or power supply.
My Toshiba laptop won't turn in. Yesterday I was
Unplug, remove battery, plug in reboot. OR, try a System Restore to a date before this issue. Have you cleaned the fan, vents, heatsink recently? Is it overheating? It would be helpful if we knew the Toshiba Model number and the OS you are using.
May 06, 2013 | Computers & Internet
Why does my torolawnmower take off when i start it?
I have a riding toro lawn mower that cut off on me and wouldn.t start back, what could be my problem? The crak wheel trys to turn but it won,t turn over
Dec 11, 2012 | Toro Lawnmower Lawn Mower SP Drive Belt...
1999 Chevy Blazer S10.. Won't start.. It was
sound you have a blown clutch slave cylinder
Dec 05, 2012 | Cars & Trucks
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
Jun 09, 2011 | Samsung Galaxy Tab Tablet PC
Won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Dec 31, 2007 | LG 42LC7D-UB Television
LG 42PX3DCV 42 in. Plasma EDTV Logo
49 people viewed this question
Computer Repairing
Computer Repairing
