Question about LG DLE2532W Electric Dryer
Not drying no heat...checked the breakers and everything OK, what should we do next?
  • 10,319 Answers
Check the exhaust vent tubing first
If lint has a build up the moister sensor will keep the heat at check
Posted on Jun 07, 2010
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Where is the cycling thermostat located?
may not be the cycling thermostat, check ur heating element, and the hi-lo limit thermostat, and make sure u have full 240 at the outlet bcuz if u have only 120 and not 240 u have enough to run motor but not the heater thus no heat? something may have tripped ur breaker. u will need to test with multi meter
Jul 12, 2014 | Samsung DV210 27 Electric Dryer with 7.3...
Not drying clothes
First check your breakers in the main box. The dryer lights and drum will spin with 110 volts only the heating element needs 220 volt if one of the breakers or fuses are tripped it will not heat. Trip the breakers off then turn them back on and check it. If it still wont heat check the heating element and wires leading to it as well as the 110/ 220 volt connector it may be bad or have a wire off, if all is ok then the heating element is probably bad and a new one needs put on.
Feb 15, 2013 | Samsung DV328AEW Electric Dryers
The Dryer do not dry anymore... no heat... the vent is ok but no heat.
Check your breaker box to make sure that both breakers are on, as one is to turn the machine, and one is to heat the element. It may be just that simple. Good Luck
Joe
Aug 29, 2011 | Washing Machines
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
It spins but won't heat to dry the clothes. I tried checking the breakers and they were fine
your heating element is burnt out it wont trip the breakers its like when a coil on your electric stove burns out, everything else works it just doesnt cook you can buy just the element and their pretty simple to install just watch for the sharp edges on the metal case!
May 26, 2009 | Dryers
No heat from dryer
You have a bad heating element and or a bad high limit switch. Check them for continuity with a volt meter. No continuity, replace the part.
May 24, 2009 | Maytag MDE2400 Dryer
Clothes aren't getting dry very fast
First, check your circuit breakers, turn them off and on...there are two linked together labeled 40 amperes or more. Next guess will be the thermostat or the heating coils. Use a multimeter to check these parts. A diagram is usually attached to the back of the unit. Oh, is the drum turning? Are your clothes reasonably damp dry when you put them in? Is the vent hose kinked when the unit is in place?
Dec 16, 2007 | Whirlpool LEQ8858J Dryer
LG DLE2532W Electric Dryer Logo
391 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
