Question about Metabo SXE450 00458 6'' Random Orbit Sander
My metabo 460 duo sander won't go could it be the carbon magnet brushes things if so how to replace these?
2 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Posted on Sep 15, 2009
How do i remove the Base?
Makita BO4900V Parts Breakdown
Beginning with pos 6 4 screws and remove pos 1 on top 3and4 both carbon brushes with holders . now you can split the armature with base from the motor housing .thats the only thing need for it.
so you can do the job . by replace the armature look for the bearing fits well in the housing again and replace the brush holders etcetera
Oct 28, 2015 | Makita BO4900V Half Sheet Finishing Sander
Drill does not work when i press the trigger
Did you take a look at the carbon brushes?. Metabo has what they call Auto stop Carbon brushes. so if they are worn down they will pop away from the motor and the drill will simply not run. this happens when the brushes are basically worn out.
Mar 16, 2012 | Metabo SBE1010PlusC 1/2" 0 900/0 2,600 Rpm...
Where can i buy some brushes for my grinder
try "ereplacementparts.com" you will need the information that you provided here to look up the schematic and then the brushes.
Jun 18, 2011 | Metabo 606405470 W21-230 9" 6,000 RPM 15.0...
1/2" metabo hammer drill-
Did you check the carbon brushes?
May 17, 2011 | Metabo Drills
Metabo paper disc Bestell-Nr-24 026 Metabo SX E 450 cling-fix sanding discs
j kjh kuyiyut khjkhkhjkgghjkghkghkjhkjhgkjhkjghkjhkghjkghjkghjkghjkkmnn,m,mn,jgkkjlkjljkliuhfgdvvvjjkjkhjkcnvbxn,mn,mnc,mxbn,mbn,vcnb,vcnxb,mnkjfkjdshfjkdsfhjsdbnmbhjmsgdifgiueryfuugadf hgadfhjdfghfdgshjgjhsdgjfgsdjhgfjhczmbmnzxcbnmgfhjga shfd
Feb 01, 2011 | Metabo 600129420 SXE450 TurboTec 6" Dual...
I have two rupes sanders, one is approx 15 years old ,the other approx 5 years old,both are stopping while working or sometimes wont turn on,if I tap the sander with a hammer then they start to work or...
it can be ascertained, there is a problem in the switch or the motor carbon brush, carbon has been eroded by the rotor rotation. you have to check and replace the carbon or switch.
Aug 05, 2010 | Tools & Hardware - Others
Brushes on my sander are wearing out within 10mins
the armature could be the problem, when you replace them do you notice a lot of arcing around the commutator, it might be bad or just need to have the surface cleaned. let me know.
Jan 22, 2010 | Makita 9404 4'' x 24'' Belt Sander
Carbon brush sizes
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Magnetic brush size
Yes and no. From 1999 to early 2008, excluding the slightly beefier "Ergo" models, the size / part number is the same. However, on the newest models there are differences in density between some models. Wire placement is different from the older models.
Sep 13, 2009 | Metabo WE14-150 Quick Angle Grinder
Just replaced the brushes in a Metabo WE14-150Quick Angle grinder
when you replaced the brushes did you notice the tool throwing sparks? Generally when I work on these after replacing the brushes I have to clean the commutator to seat the new set. You could also have other problems, e.g. bad brush holder (did you replace as assembly or just brush) Let me know what happened to the first set and if when you plug in and try it does it come up to full speed.
Sep 12, 2009 | Metabo WE14-150 Quick Angle Grinder
Metabo SXE450 00458 6'' Random Orbit Sander Logo
50 people viewed this question
Top Metabo Tools & Hardware - Others Experts
john h
Are you a Metabo Tool and Hardware - Other Expert? Answer questions, earn points and help others
