Question about Dryers
Dryer has stopped heating. the drum works it does not heat. Have cleaned lint trap and vent
  • Dryers Master
  • 1,144 Answers
Check power to the elements. check elements for continuity with meter. check for blown fusable link.
Start there.
Posted on Jun 07, 2010
What is fault code 6 mean?
Hi Darrell, The link below is about how to trouble shoot and fix your dryer.....I hope this helps.....CHEERS..
http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
The most common causes for an electric or gas dryer to stop drying or heating is:
1. The dryer lint screen (lint trap) has not been cleaned (poor or restricted airflow).
2. A clogged or kinked (bent) dryer air vent hose (inadequate or no airflow).
3. Drum has stopped turning, broken drum drive belt.
4. Overheated or bad motor (possible thermal overload).
5. Thermal fuse or thermostat (could be caused from dryer air vent hose lint buildup)
6. Heating element burnt out.
7. Loose electrical plug or power socket.
8. Other mechanical issue, fault or malfunction.
Mar 31, 2016 | Fisher and Paykel DGGX2 Dryer
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
What to check when Dryer heats, but not moving air?
Does the dryer sometimes stop heating? Do you always use the lint trap when using the dryer?
May 02, 2014 | General Electric GTDP490EDWS Front Load...
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
The drum will turn, but no heat
Well if it's a gas dryer and if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Kenmore Dryers
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Kenmore Electric dryer not heating drum
Check your vent line if it is stoped up you have no air flow bent ocrushed check the flap is not stuck
Dec 12, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
