Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Makes buzzing noise with each cycle. Does not do anything.
  • 5,081 Answers
1st, if you take the back plate off the washer, you will be having a lot of work to put it back on, it is very tough to replace, as the cabinet is designed to be removed from the front.
2nd, if the motor is running, but nothing is running, then the coupler may be broken or stripped. and it will need replacing, the part is about $12.
3rd, if the buzz is coming from the motor, but the motor is NOT running, or spinning, then the transmission may be frozen and in that case you may need to replace the washer, as transmissions are about $165 for just the part.
Posted on Jun 07, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My washer makes a buzzing sound when trying to go through spin cycle. Cold water doesn't work either but other temps do.
check for a faulty cold water solenoid in the machine
the buzzing noise is a cycle frequency noise caused when a solenoid coil is faulty and not moving the centre bit.
May 28, 2015 | Washing Machines
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Noisy Dishwasher
it is a capacitor to start the motor for the next cycle. I think it is inside the door. you may have to call a tech.
May 19, 2013 | Whirlpool GU2300XTVQ Builtin Dishwasher
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Air Conditioner makes a loud buzzing noise now. It didn't do that before, now it makes so much noise I can't hear anything over it
Buzzing noise - contactor. maybe a bug got in the contacts or maybe the coil is bad but in any case if you replace the contactor the buzz will go away.
May 23, 2009 | Goldstar Heating & Cooling
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Oct 29, 2007 | Dishwashers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
