Question about Apple iPhone Smartphone
My iphone ha frozen
My iphone has frozen while i waz charging it i want to turn it off and then back on but is not working how do i open the iphone to remve the battery
  • rockway42 May 10, 2008
    Ok, iPhone went into the pool. Yeah, I know...Im an idiot!! Put in in a bowl of dried rice for 24hrs to absorb the moisture. When I plug phone into comp, battery charging indicator comes on for a while then tells me to try to go to Itunes. comp cannot see phone. after battery charges a while, phone shows apple icon and just keep blinking on and off. Is phone trashed??? Can it be reparied??
    thanks!
    wayne
  • solomon_prai Dec 31, 2008
    i m trying that.. but it turns off.. and doesn't.. go to the recovery mode!!
Thanks chakubiz. My iphone was frozen, and couldn't get it to do anything. I held the Home key, and Power key at the same time, just like you suggested, and it worked. The phone came back to life.
Posted on Jun 12, 2008
    Problem Solver:
  • 5 Answers
Dont do thatremoving battery creates more problems. hold the power key n home key b patient just keep holding some thing will happpen. then the next screen will put phone in recovery mode
Posted on Apr 12, 2008
Kobo screen frozen
If your kobo happens to have a frozen screen showing connected and charging plug it back into the device it was plugged into when you removed it. It will work. Trust me
Apr 08, 2014 | iPhone Apps
MY IPHONE DIED AND NOW WONT TURN BACK ON
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.
Second I would check to make sure the battery is actually charging.
Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
Jan 09, 2013 | Apple iPhone4 4G iPhone 4
Iphone has frozen. Won't take calls, won't turn
hold on the power and home buttons until the screen goes black, once black keep holding the buttons until you see an apple logo then release, this is a soft reset. if this doesnt work plug into itunes and when the computer recoginizes it click restore. this will delete everything on your phone and take it back to the way it was when you bought it.
May 10, 2010 | Apple iPhone Smartphone
The apple logo on my iphone is frozen. iphone 3gs
try restoring ur iphone 2 the factory setting using itunes
Mar 03, 2010 | Computers & Internet
Iphone is frozen on startup can see aple icon. wont turn on or off.frozen
This some times happen, you iphone should be fine though.
- connect your iphone to the Computer
- open itunes
- hold down the on/off button at the top and the home button at the bottom at the same time for up to 3 full minutes.
- you will see an error from itunes that the iphone is in recovery mode
- click ok
- then choose =Restore=
Good Luck
Nov 04, 2009 | Apple iPhone 3G
My iphone won't charge or turn on and its just at a black screen
Hold the on-off button and home buttons together for 5 sec as the iphone is connected to a charger, then release both buttons. Then press the on-button. The iphone should now turn on if it was just frozen. If not, you may have a hardware issue. There is an iPhone Repair Guide that shows how to open an iphone and replacement parts are available on Ebay.
Apr 03, 2009 | Apple iPhone Smartphone
My iphone wont turn on
hold down the power button on the top right hand side and the home button on the bottom of the touchscreen. Wait for a white apple then release.....it should start up the phone if it is frozen
Mar 20, 2009 | Apple iPhone Smartphone
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Not Charging
well its a needle in the haystack problem, ha ha First thing I would do is take the battery out and put back in, to maybe insure the connection was there. Maybe U know someone with a electrical meter that can check your charger out, for output charge and the battery. Last but not least take it back.
Jan 04, 2008 | LG KG800 Cellular Phone
Iphone frozen
Hi there, i need more information, like define frozen? doesnt turn on? its on but doesnt respond? etc..
Z33m
Oct 27, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
142 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
