Question about GRY Viore RPT50V24DHD 50" HDTV DLP TV
My remote doesnot turn my tv what do i do - GRY Viore RPT50V24DHD 50" HDTV DLP TV
  • 456 Answers
Check the batteries arent flat, and if your remote still doesnt function you have two choices to try and fix this problem,
1, You can dis-assemble the remote and clean the button pad with warm soapy water as well as clean the inside of the case to remove any grime or gunk that id hindering its opration.
2, You can take it to a repair shop and they can do the same and also test it with a IR tester, (aka , a remote tester).
Just ensure you let it dry out completely before re-assembling if doing your self to prevent the remote shorting out. Good luck.
Posted on Jun 07, 2010
REMOTE RM-C1221 REPROGRAM
test the remote control, use the digital camera, and point the remote control press any key the LED must TURN ON , SEE THE diagram attached. If doesnot , you must open the remote control,clean the keypads for dirty, oxide. b) resolde cool join in LEDS c) resolder the contact terminal battery, and clean it. God bless you31d019d2-eaa4-43ea-a5df-8f28eb74dd2b.jpg9415c727-5ddf-4bf0-9b77-883d9fe7bf49.gif
Mar 30, 2013 | JVC Televison & Video
Remote 27185-560 light in center of remote stays on will not go off
1) replace the batt by new ones.
2) clean the contacts batteries with c. cleaners
3) Retight the springs contacts from batteries for better contacts very important, use pliers.
4) If this doesnot work, open the remote, and clean the keypads, from dust, dirty, oxide. with c. cleaner.The syscom must be work very clean, sending signa I.R transmission
5) if this doesnot resolve the problem go to the repair shop TV, for fix it. see the block.
God bless you
Sep 06, 2012 | Hunter Televison & Video
I have a Magnavox converter box model TB100MG9 with a ge universal remote but cant get it to turn on?
replace the batteries by new ones.
3) retight the contacts batteries springs with pliers, for better contacts.
4) if this doesnot resolve the problem, open the remote, and clean the keypads from oxide, dust, dirty. The syscom send I.R signal very well, will be importante to do that.
5) If this doesnot resolve the problem, go to the repair shop TV for fix it.
God bless you
Sep 06, 2012 | Televison & Video
Can't turn on my direct tv from remote
1) reset the code again.
2) clean the contact batteries
3) retight the spring contact batteries for better contacts
4) resolder the wire contacts batteries.
5) try again,
6) if doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 20, 2012 | Raymarine Televison & Video
Can't turn my direct tv on from the remote after a long period
1) change the batteries
2) clean the contacts batteries with contacts cleaner
3) retight the springs contacts with pliers for better contacts
4) resolder the wires contacts batterie
5) open the rem.control clean the keypads swtich for dirty, oxide, bad contacts use the continuity or open contact and repair.
6) try again.
7) if doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 20, 2012 | Televison & Video
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
TV does not turn on
how many times does the red light blink?
Jul 21, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
GRY Viore RPT50V24DHD 50" HDTV DLP TV Logo
83 people viewed this question
Top GRY Televison & Video Experts
Paul Bade
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul
Are you a GRY Televison and Video Expert? Answer questions, earn points and help others
