Question about Verbatim VER95327 USB Hard Drive
Verbatim external hard drive stuck
I have a 500G Verbatim External hard drive. I googled how to format and partition it so that it would work with my mac. I used the disk utility and it went just like the instructions said. It causes the mac to hang up in the middle of programs when it is plugged in. It does not want to eject properly and now the screen is stuck on "scanning".
SOURCE: external hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Posted on Apr 10, 2009
  • 12 Answers
SOURCE: Undetectable External hard drive
i am unsure about this but its worth trying
go to start control panel administrative tools services and look for plug and play and make sure it is set to auto at start up and enabled it so it is started this lets your computer recognize new hardware on your computer which should let see it in your my computer screen
i hope this as help if not well i tryed
Posted on May 01, 2009
SOURCE: verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
Posted on Feb 23, 2010
lock123
  • 6831 Answers
SOURCE: Verbatim 160 USB external hard drive does not show
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 10406 Answers
SOURCE: does the verbatim harddisk external
Yes. It's one of the features of the USB hardware interface,
and it's necessary for the Mac Operating System to be 'compatible' with the file-systems used on Windows computers.
Posted on Oct 07, 2010
My Verbatim 2TB external HD was used as a recovery drive when updating a PC, it now only shows 32GB storage, I'm running Windows 10 or Windows 8.1 what can I do to restore it to its original state?
Assuming you have transferred any data you may need from the drive to another drive (important!) , you should be able to remove the existing recovery partition from the external drive, re-format it with the NTFS system, and you should be good to go.
Here is a link to a free partition manager. I do not represent this company or any of its products. There are other partition mangers as well. You can view them here:
http://www.freewarefiles.com/search.php?query=partition&boolean=exact&B1.x=0&B1.y=0
http://www.partitionwizard.com/free-partition-manager.html
Jul 15, 2015 | Verbatim Computers & Internet
My fabrik simpltech 500g hd doesnt work on anything but my macbook, is it locked?
If it's formated under MAC OS, windows will never see partitions on your hdd.
Dec 25, 2011 | SimpleTech 500GB SimpleDrive Pro External...
Backed up once successfully but any subsequent tries it says 'no space left' on a 320GB Verbatim external hard-drive. Any ideas?
hi
i would format the external dive and then back up the system hard drive on to it. save any necessary data or files onto CD first-- but if you have a back of the hard disk on this external, no need to keep more than one image copy of the computer hard disk drive. i had to format my external. i do not save anything that is of persoanl value on external drive. if i can i save up to 750M of persoanl data on several CDs
please send me 4 thumbs up
Jul 16, 2011 | Verbatim Smartdisk Clon Portable 97061...
Drive was working fine. I deleted the partition and then connected the drive again and it is not recegnized by the PC. The message scanning keeps showing in the drive and it does not work.
dont open my computer
open start menu ------- control panel ---- Administrative Tools ----- Computer Management -- storage ---
disk management ---- the you fix things up but dont forget to format after create a new partition
May 29, 2011 | Verbatim InSight 320GB USB 2.0 2.5...
Verbatim Model #USBPRO500 Shows up on list of
use the source (pc/Mac) that created the data to remove it.
you will need to re-format to get it to work on the machine you are currently trying to use.
(personally I always remove all partitions and format to "fat" (remove factory) this will make the drive work on Mac as well as pc)
hope this helps
Dec 14, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
Nov 04, 2009 | Office Equipment & Supplies
My verbatim 250gb external hard drive light goes on when i plug it in but it doesn't show up on my laptop nor my desktop...
First, have you checked on your Disk Management if the external drive is being detected? You will need to initialize it from the there.
To do this, right click your My Computer and choose Manage. At the left panel click on the Disk Management. The list of available drives will show on the right. You might see your 250GB external drive as "unallocated".
Right click on the drive and a window will popup. Select create partition (primary partition). After you've selected your partition , now you need to format the hard drive. Choose quick format. Right click again on the partition you've just created, now select "Format" and select NTFS. Click ok and it will guide you until it is finished.
Please let me know if you need further assistance. Hope this helps.
Oct 07, 2009 | Computers & Internet
I have verbatim external drive usb 2.0. It used to function properly...but now Windows(xp) doesn't open it at all and properties reflect only 2.95MB space. Its a password protected USB and doesnt even show...
update drivers. other people are having trouble with their verbatim products not registering. If you have any more problems, like finding drivers, e-mail verbatim directly with your problem.
Sep 15, 2009 | Verbatim External, USB 2.0, 750GB...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Verbatim 120GB external hard drive
goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Mar 16, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Verbatim VER95327 USB Hard Drive Logo
116 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
