Question about InFocus LP640 Multimedia Projector
Projector projecting backwards or like a mirror image
  • 75 Answers
You have it in rear projection mode. Do the following go into settings>system menu and turn off rear in settings>system menu.
Posted on Jun 07, 2010
Words are showing backwards
Your projector has been set up for rear projection - you need to change it to front projection. Access the setup menu, then use the option to flip the image horizontally. Viewing the image in a mirror may make it easier for you while navigating through the menu options
Mar 27, 2014 | InFocus Office Equipment & Supplies
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
Mar 27, 2014 | NEC VT465 Multimedia Projector
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
MacBook connected Hitachi CP x301 Icons do not appear
Ok what's happening is that you have it set up as an extension of your desktop, you need to mirror the displays. when your projector is plugged in and it is showing only the desktop background, open "System Preferences," click "Displays," click "Positioning" and check the box that says "Mirror Displays." This should do the trick.
Mar 28, 2009 | Hitachi CP-X301 Projector
Someone changed a setting
The setting is in the Menu. It sounds like you went to the "Image" section which lets you make the adjustments you list. Try the "Source" menu, then "Mirror". That's where you will find options for Rear Screen Projection, which makes the image backwards.
Feb 05, 2009 | BenQ MP610 Multimedia Projector
Infocus projector, words projects backwards
change the orientation from rear to front in the menu
Dec 29, 2008 | InFocus In2102 Projector
Yellowed image projection
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
Oct 23, 2008 | Sanyo PLC-SW30 Multimedia Projector
Upside down projection
Hi career link
If you enter the User Menu on the Projector you will see a subfolder that will read Mirror or Flip Image.
Scroll down to this folder and press left or right until the image is flat fronted ( table front projection )
Thanks for using Fixya !
May 21, 2008 | Sanyo PLC XW20A Multimedia Projector
Nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Apr 09, 2008 | Office Equipment & Supplies
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
InFocus LP640 Multimedia Projector Logo
1,660 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
