Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi CS30 - Stalls out?
Ryobi CS30 - On START, Pull cord and runs perfectly ! Switch to RUN, stalls out. Cant seem to keep it going? thanks
    Problem Solver:
  • 15 Answers
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Posted on Jun 07, 2010
    Problem Solver:
  • 5 Answers
Clean the muffler. Also check the head gasket. I replaced mine and cleaned muffler and it works well now.
Posted on Jun 12, 2010
Ryobi leaf blower stalls when i give it gas idels fine but when i pull the triger it stalls
remove the muffler and run it if ok with the muffler off open it up and clean the screen inside
Jun 14, 2012 | Ryobi Garden
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
Trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
May 22, 2010 | Ryobi Garden
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I HAVE A MODEL775R RYOBI GAS TRIMMER 31CC IT HAS NO SPARK.
you probably made the mistake of leaving it in the shed over winter with gas in it.
in the carb there is a diaphgram that oumps this fuel in via the motor vibrations.
said diaphgram had been ruptured due to drying gas in the carb. the solver to this is to either have a small engine mechanic replace it or the whole carb or get a new one, and i would suggest you get the cs26 model instead. i have a cs30 and cs26 and i have had less problems with 26. it only has two chokes.
you prime it.
you push lever to start, closing all but a little bit of carb,giving engine much richer mixture.
you squeeze trigger, opens halfway/full, as there are two chokers in the carb, on controlled by lever and another by throttle.basically now you haave half choke.
you release trigger, goes back to 7/8 choke to keep at idle but not running. your ready to go.
on the cs30 its much more complicated:
ful choke
prime 7x.
pull 4x
half choke
pull till start.
wait ten seconds of running at idle rotate to run
good to go. but these guys have porr design. if you take off the back cover and look above fuel tank on cs30, the crank is RIGHT SMACK THERE and not better secured like in the '26 model.
that's what the little circular hole is in it.
anywho, the diaphgram is ruptured, and you probably haven't noticed that in addition you have gas leaking out the carb's air intake.
May 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi weedeater engine keeps stalling out.
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel too, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
Nov 30, 2008 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,846 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
