Question about Car Audio & Video
97 lexus factory nakamichi amp draw
We have a 97 lexus ls400 with a factory namamichi amp. The amp has a short in it creating a draw on the battery when the car is off. Lexus says the amp has been discontinued. Do you know where we can send this amp to get repaired or buy a new/reman amp.
    Novelist:
  • 100 Answers
Are you sure that the amp is what is causing the current draw? Try pulling out the amp fuse and radio fuse in your fuse box and see if the battery still dies. But, I would go to a local car audio shop. The company that we used when I worked at the shop was United Radio, you might be able to contact them about a quote if it is shorted. Another option is searching ebay, or a scrap yard. I'm sure there are plenty out there somewhere. Good luck.
-Andrew Hawkins
Posted on Apr 11, 2008
Where is crank shaft sensor location on 95 lexus sc300 please help
images for Where is crankshaft sensor location on 95 ...
eplaced engine on '97 SC300 now new engine does not have Crank ...
www.clublexus.com/.../633233-replaced-engine-on-97-sc300-now-new-...
May 4, 2012 - Location: arizona. Posts: 3 ... apparently 95-97s had an additional crank sensor. .... 1995 Lexus SC300 5spd Na-T ( TT Ecu Mod + a few others) 2jzge position sensor??
Nov 2, 2011
SC400 Crank Shaft Position Sensor. WHERE?????
Oct 11, 2011
SC300 No Spark
Oct 2, 2010
What happens if the Camshaft Position Sensor goes bad?
Jun 18, 2009
More results from www.clublexus.com
Lexus Crank Position Sensor ' LS400 SC300 ES300 GS300 ...
www.partsgeek.com > Crank Position Sensor > Lexus Parts & Accessories
Products 1 - 10 of 68 - 95 1995 Lexus LS400 Crank Position Sensor Denso NLA 7/13 ... 96 1996 Lexus SC300 Crank Position Sensor Denso Includes Pigtail.
Jan 27, 2016 | Lexus Cars & Trucks
My 1995 Lexus LS400 has 120-130 psi compression in all 8 cylinders, does anyone KNOW what factory specifications are?
1995 Lexus LS400 specifications, information, data, photos ...
www.carfolio.com/specifications/models/car/?car=23507
1995 Lexus LS400 automobile specifications & information. ... The Lexus LS400's engine is a naturally aspirated petrol, 4 litre, double overhead ... 4 valves per cylinder... bmep (brake mean effective pressure), 1171.5 kPa (169.9 psi ).
Aug 01, 2015 | Lexus Cars & Trucks
Ls400
you need make a diagnostic to know what happened to your car of course you need an auto diagnostic tool first: http://www.chinasnoy.com
May 21, 2013 | 1992 Lexus Ls 400
How do i turn on the radio in a ls400 1998
The Nakamichi radio in the 1998 Lexus LS400 is turned on by pressing the large round button on the radio in. This same button also controls the volume by turning it clockwise or anticlockwise. The radio will use the same audio input that it used when it was turned off. The input can be changed using the series of buttons on the right side of the radio, tape, cd, fm, am.
May 24, 2012 | 1998 Lexus LS 400
I need a Nakamichi subwoofer amplifier for my '91 Lexus LS400.
I found a few on eBay with this link...all others are out of stock but I'm sure you knew that.
http://shop.ebay.com/i.html?_kw=nakamichi&_kw=amplifier
Jan 05, 2011 | Pioneer GM5400T 2-Channel Bridgeable...
How do i locate the factory amp in a 1990 lexus ls400
in 1990 LS400, the amp is only for the sub, its located between the fuel tank and trunk liner. you can reach it by removing the trunk liner which cover the fuel tank right behind the rear seat. hope this helps
Mar 30, 2009 | 1990 Lexus LS 400
Lexus ls400lexus LS400 nakamichi cd car stero AMP troubleshoot
reset the 3 breakers located near the fuse box by putting a tiny pin into the slots till you hear a click.
Apr 26, 2008 | Car Audio & Video
1990 Lexus LS400 Nakamichi Car Stero Amp problems
if the amp is damage it needs to be repaired or replace but the age of any amp doesn't matter, all are compatible to work.
Jun 18, 2007 | Nakamichi PA-2002 Car Audio Amplifier
Car Audio & Video Logo
243 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
