Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU
Sta Rite max e therm 400,000 not heating water. Heater running but not heating. Has gas Service heater light on. What do you suggest we check. We do not have a manual for the heater
    Habit-Forming:
    New Friend:
  • 18 Answers
First of all measure voltage if you have power on cables..then check contonuity with off position if heater elwment is broken .intrerupt or has continuity.best regards
Posted on Oct 01, 2017
    Top Expert:
  • Sta Rite Master
  • 8,163 Answers
Check ignitor and gas
  • 88 Answers
SOURCE: service heater lite comes on
yes you can ,go to starite.com,when the page comes up at the very top there is a button that says owners manuals,just click on that and you will probably have to have your model #.hope this helps.
Posted on Dec 06, 2008
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
  • 246 Answers
SOURCE: I have a Sta-rite gas heater that has the afs and
SORRY YOU HEATER IS GONE THE HEAT EXCHANGER HAS ALEAK THIS IS DUE TO POOR WATER CHEMESTRY ,LOW PH, OR SOMEONE USING TABLETS ON THE SKIMMER THIS DAMAGE THE METALS ON THE HEATER
Posted on Oct 13, 2009
  • 246 Answers
SOURCE: sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Posted on Dec 07, 2009
I have a Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU and the pool pump and heater work fine untim the next morning. The pool pump comes on and the heater does not. The service light...
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
May 29, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Heater will not ignite' service light is on?
I suggest that Sta-Rite technical support would be the best ones to help you determine what the problem is. I hope this helps.
Aug 09, 2011 | Sta Rite Sta-Rite Max-E-Therm High...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Sta rite heater won't start
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Oct 09, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU Logo
156 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
