Question about Cycling
Hello, I have replaced my bicycle chain, now i need to reset my cantilever gears, 15 speed. Thanks.
    President:
  • 1,561 Answers
I will advice you check the manual that came with the bicycle, this will give more highlight and information on how you can do this.
Take care.
Posted on Jun 08, 2010
How do the gears work
Have a read and watch some videos.
  • How do Bike Gears Work? ' Design Squad - YouTube www.youtube.com/watch?v=oauDyIu_swM
    • BY DESIGN SQUAD GLOBAL
    • 3 MIN
    • 107K VIEWS
    2012-10-12 · How do Bike Gears Work? ' Design Squad ... What Is Inside A Bike Freewheel/How Does It Work? - Duration: 3:56. RJ The Bike Guy ...
  • Bicycle Gears - How Bicycles Work ' HowStuffWorks adventure.howstuffworks.com/outdoor-activities/biking/bicycle3.htm Bicycle Gears - Bicycles aren't just for kids. ... How Bicycles Work. by Marshall Brain Adventure ' Biking. Bicycle Gears. Prev Next . You have ...
  • Bike Gears: How Do They Work - Sportive Cyclist sportivecyclist.com/bike-gears-how-do-they-work Now, if you'd like to learn more about bike gears, and chainsets in particular ... Bike Gears: How Do They Work (learn what terms like '53/19? mean) ...
  • Bicycle gearing - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Bicycle_gearing Bicycle gearing is the aspect of a bicycle drivetrain that determines the relation between the cadence, ... Hub gears work using internal planetary, ...
  • How to use Bicycle Gears ' Gears on a Bike bicycleuniverse.info/eqp/gears.html How to use Bicycle Gears. ... This works because the higher gears move you farther for each spin of the pedals, making you do more "work" ...
  • Hub gear - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Hub_gear A hub gear, internal-gear hub, or just gear hub is a ... 1959 Elizabethan Apr. 35/1 My lightweight bike with 4-speed hub gear ...
  • Technique: How to use your gears efficiently ' Total Women ... totalwomenscycling.com/...how-to-use-your-gears-efficiently-9497 Total Women's Cycling . ... Find out how to change gears on a bike and learn to use your gears efficiently, ... Liked this guide on how to use your gears efficiently?
  • How do bicycle gears work? - Ask.com www.ask.com > ... > Biking & Cycling > Bicycles Bicycle gears work by moving the bike's chain on varying chainring and cog combinations to match the desired drive wheel speed, cadence and pedaling speed of ...
  • Apr 21, 2016 | Cycling
    Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
    This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
    Try to not use the big rear sproket and the the big front chaining at at the same time,
    Apr 24, 2015 | Shimano Cycling
    What does each gear mean, ie.: is gear 1 for hills, etc. what do I do if chain comes off? If I need a part, where do I go to get it?
    1. The ratio of the driving gear to the driven gear is the gear ratio. Lower ratios give higher torque; higher ratios give higher speed. You can't have both.
    Search engine "how do gears work on a bicycle"; "what do I do if chain comes off"; "how to shift a bicycle". Many videos and resources.
    2. Bicycle shops, eBay, online Search Engines
    http://www.parktool.com/blog/repair-help
    Jul 11, 2011 | Cycling
    How do I operate the 8 gears on my bicycle as I have no instruction manual ? Please advise. My bicycle is a "Carolina Free Spirit". Thanks
    Google bicycle shifting technique, for example:
    http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
    The basics of shifting are these:
    1) The big ring and right side of the cassette in back are for speed.
    2) The small ring and the left side of the cassette are for high torque, lower speed
    3) The middle ring works with all rear cogs.
    Avoid crossing left front to right rear and vice-cersa. It cause excess side loads on the chain.
    Mar 07, 2011 | Cycling
    Question, . . need to replace chain Will a Sram PC-971 Chain work on my 8 speed road bike? Thanks T.K Yandell
    Nope - This is a 9spd chain. The gears on a 9spd are narrower than on an 8spd. If you are going to use a SRAM chain you need one that starts with an 8 such as PC-850.
    Any 8spd chain will work fine, Shimano, SRAM, whatever.
    Nov 21, 2010 | Cycling
    We need to replace the bicycle chain. I'm the grandmother and need help. Thanks
    Depends, is it a single speed? Then you buy one with a master link. If, it has gears you need to have a chain tool. I would go to a local bike shop and have them replace it. I am sure that you will only pay a minimun charge to install it right for you. We do it while a customer waits, it is that quick of a job.
    Oct 21, 2010 | Cycling
    Can i remove a 5 gear sprocket from 26" tire, and replace it with a 7 gear sprocket from a 20" tire? my roomates touring bike is currently a 15 speed, she loves the bike and does not want to replace it....
    Several scenariosto consider here. First of all the compatibility with the hub. Second is the deraileur tarvel and the actual shifter. Components are normally matched in sets from factory and do not transfer over unless the entire set, shifter, deraileur and sprocket. Then there is the issue of chain wear fitting the crank and new hub together. Chains and gears seat into each other as they wear so a crank set should stay with the original hub as well, even if you were to install a new chain the wear pattern would be different.
    So the short answer is unless the brands all match and are in new condition and the hubs are the same thread and diameter, you will not get good results
    Sep 14, 2009 | Blackburn Mountain Air Mountain Bike Pump...
    I need to set my bicycle chain on a single gear
    well there is a place on the chain that can unlink. it might be hard to find but it is there. then simply wrap it around the single gear.
    Mar 31, 2009 | Springer 26" Stretch Beach Cruiser
    The chain wants to jump off while trying to change gears
    There are several things that could be wrong:
    Shifter out of adjustment
    Chain worn
    Chain and gear(s) worn
    Shifter out of adjustment:
    Try adjusting the cable tension by turning the barrel (the part between the cable and the shifter). Count the number of turns and reset it to its original position if this doesn't solve it.
    Chain worn:
    Chains wear out. hold a ruler up to it, with one end centered on a pin. 12" away, another pin should like up very very very close to the 12" mark. If not, it's probably worn out and needs to be replaced. No way around it. Some say chains are good for 500 miles only. Your mileage may vary. (keep reading...)
    Chain worn and gear(s) worn:
    If the bike has been ridden witha worn chain for a while, it will make the gears in the back wear faster too, and a new chain alone will not work. If this is the case, you need a new chain and new gears in the back. Often, gears in the back are replaced all at once in a 'cassette'. You'll have to make sure your front gears aren't worn out too!
    Nov 15, 2008 | Huffy Cycling
    Cycling Logo
    20 people viewed this question
    Top Cycling Experts
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
