Question about Samsung HL-T5076S 50 in. TV
Tv dont turn on
Tv don't turn on green light blinks goes red for a moment then green then all 3 start blinking #hlt5075sx/xaa
  • ttrevino12 Jun 07, 2010
    Just want 2 b sure be4 I by lamp
    Thanks
  • 10,515 Answers
First I want to be sure you are using a genuine samsung lamp exact part number and the exact ballast new from the factory. If you have purchased the parts otherwise,you may have a part that was returned. Please recheck your steps and be sure all connections were made upon replacement. On the ballast..........there is a small fine connector which goes to the DMD (big silver module) be sure wires are connected on both ends and the cable is ok. The next suspect in my opinion if all this is ok would be the DMD board,but I have repaired every one so far with the exact lamp and ballast..........good luck.............. Be sure the lamp door is closed and the internal switch is closed ........you may have to check or remount that black plastic bezel
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 07, 2010
  • 10,594 Answers
All three lights blinking shows that lamp inside tv is dead and need to be replaced.
lamp replacement procedure is easy and would be mentioned in user manual, buy Samsung original lamp and replace it to fix tv issue.
Let me know if you have additional question.
Thanks.
  • Shahid Electronics
    Shahid Electronics Jun 07, 2010
    Just replace lamp in tv to get it sure.
    Was it lamp or any thing else?
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Apr 08, 2009 | Sony Grand WEGA KF-50WE620 Television
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung HL-T5076S 50 in. TV Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
