Question about Kenmore 70066 Air Conditioner
It died during the winter, it was great all last year, no problems. Today i turnred it on, nothing. where to start? who to call?
    Novelist:
    Champion:
  • 246 Answers
Make sure the outlet that you have it plugged in to is in good working order. i.e. plug a lamp/hair dryer in and see if it works
Check the breaker.
Posted on Jun 11, 2010
Intermittent starting problems with my 1990 Honda Accord
Have you looked into your crankshaft sensor
Jan 22, 2014 | 1990 Honda Accord
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Two years ago i purchased a Craftsman riding mower with a Briggs&Stratton 24 hp inteck v-twin, it ran fine the first season but that was it. Last year i tried to get it started by changing plugs and...
Gas is so poorly refined these days, Youll notice the fuel stabilizer says it is only good for about 30 days. although i cant give specific instructions on how to clean out the clogged jet in your carb, if it runs on starting fluid, a clogged jet is deffinately your problem. start with the float bowl make sure it has clean fuel in it and the primary jet is usually in the bolt that holds the bowl on make sure its clean and if the float hanging down opens the needle valve and fuel flows your good to that point. if the engine still wont run, or only runs with the choke on. get some carb cleaner spray and go at it, make sure you can blow through every port and jet, BUT WATCH YOUR EYES you never know where that stuff is going to exit.
next year winterize it, drain the fuel and run it till it dies.
or i like to winterize my engines by replacing the regular fuel with a little bit of aviation fuel as that stuff can sit for years, just dont operate or mow for more than 2 or 3 minutes on it.
Good luck
Apr 22, 2011 | Briggs & Stratton Briggs Stratton Intek V...
During the past two winters I have had enormous problems starting my car. Have new battery, new starter, crank shaft sensor and many other new parts. Mechanics cant figure out what is wrong. Its as if...
I had the same problem with my Blazer last winter. I had the fuel injectors replaced and now it starts fine. If you haven't had them changed in a while that is probably your problem.
Dec 04, 2010 | 1989 Buick Skyhawk
Iginition system does not get power
did you check all the fusable links sometimes they dont break all the way maybee check all the grounds on the truck there is one on the back of the head and should be a comp. ground and of course the engine ground from bat. sometimes you have to losen them and retighten to establish a new clean ground
Aug 15, 2009 | 1995 GMC Sierra
2001 Camaro Battery/electrical problems in cold weather
check all the connections. espc. the ground cables
Dec 09, 2008 | 2001 Chevrolet Camaro
1998 toyota corolla will not start in cold weather.
check ur starter motor,n if it a carburator operating engine,when the engine is cold choke it,n turn the start it should work,
Dec 02, 2008 | 1998 Toyota Avalon
Geo metro 1993 battery dies
most likely a light is staying on somewhere. Remove the light in your glove box, as the most likely culprit and see if the battery is good.
Nov 21, 2008 | 1995 Geo Metro
Kenmore 70066 Air Conditioner Logo
24 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
