Question about GE Monogram Side by Side Refrigerator
GE Monogram refrigerator feeezing even when thermostat is set at 45
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jun 07, 2010
Testimonial: "Suggestion was helpful diagnosing. We had to search for diagrams to find the damper door, which was broken"
Compressor doesn't start when fridge is plugged in
The board or the cold control thermostat depending on model is bad. If it has a board, that Board most likely also controls defrost which may be why your coils are feeezing if Board is bad.
Oct 22, 2017 | GE GSL25JFPBS Side by Side Refrigerator
GE Monogram ZIRS36NMHRH coils at bottom of fridge freeze up on one side and the temp is not as cool as it should be. This happened 2 or 3 years ago and we replaced the evaporator, but here we are again. ...
Hi Michelle, most likely your unit is having a problem defrosting. I recommend getting a professional on this one. The defrost heater, thermostat and timer need to be checked to determine what is malfunctioning.
Nov 21, 2013 | GE Monogram Side by Side Refrigerator
GE Monogram ZISS420N - Freezer works fine - refrigerator side is also freezing with thermostat set on 45 - repairmen (if you want to call him that) on five seperate occasions replaced thermostat,...
We are GE Monogram factory authorized service & parts and this issue sounds like your control board to your fresh food has gone out. The control board controls all the parts on your GE Monogram. You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance service issue and to get your parts.
We hope this solves your issue and we look forward to working with you.
Nov 07, 2009 | Refrigerators
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Monogram freezer not freezing food & refreegiration side not cold enough
first thing to look for is the freezer fan running. then is the air circulating in compartment. blockage is a cause. themostat setting is important.you can leave freezer door open and trigger the door switch.you should feel cold air comming ot. i know it may sound silly check to see if freezer light goes off when shutting door. fan,circulation,cold air input.thermostat,lightoff. good luck
Jun 28, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram Side by Side Refrigerator Logo
644 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
