Question about Sport & Outdoor - Others
Starter was removed, rebuilt and reinstalled. Looking for help fo correct wiring. The starter has 1 small post and 2 large brass posts. 1 at the top and the other atthe bottom There are 5 wires - red battery cable - red & yellow (Small post?) - 2 red - 1 orange What could happen if the combinatio is not correct when I connect the battery? I believe the serial # is LD64157 1998 Sey ray 3.0 L mercruser 135 HP
    Brigadier General:
  • 3,513 Answers
Attach the orange wire (FROM THE ALTERNATOR) to the stud on the starter solenoid that you connect the red battery cable..
Looking at the studded end of the solenoid, the small stud on the right side gets the yellow w/red stripe from the slave solenoid. The strapping coming out of the starter should be connected to one stud already. The empty large stud gets the two red and the orange wires."
The Red/ Yellow wire goes to the Small stud, closest to the block,+ All the other wires go on the vacant Big stud.
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 07, 2010
  • garryhickson Jun 07, 2010
    Thank you for your advise. I just noticed that 1 of the red wires is in fact red with a purple stripe. There is a black box(approx 1"X 1") attached and this has a large connector to be attached to a post.
    I'm a little confused. You indicated the orange cable should be attached with the red battery cable but you also said the orange should be with the other red wires. Please clarify. Would a camera shot help?
    There is a wire already attached to 1 of the large posts. Should the battery cable be attached to that post or the empty one?
  • garryhickson Jun 08, 2010
    Did you get my email sent abour 12:30 last night?
    Garry
My yardman he 4160 starter solinod wires are not connected there are 2 red thick cables and 2 thin cables can anyone help
One large cable comes from the battery and goes on one large post of the solenoid.
The other large wire goes to the starter and goes on the second large post on the solenoid.
It does not matter which post you choose.
The small wires ... if they have large ends that would fit the large posts, will go on the battery cable side of the solenoid.
The small wires ... if they have small ends, and your solenoid has two small posts, should be installed on them. Again, it does not matter which post, install one on each.
Jan 22, 2017 | Garden
SCHEMATIC STARTER FOR 1993 CHEVY SILVERADO PICKUP
The small wire from the ignition switch goes to the small post on the starter solenoid. The large wire from the battery goes to the large post on the starter solenoid.
Jun 30, 2015 | Cars & Trucks
I have a 1999 chevy cavalier and i got a big suprise when i went to start the car i found out someone had got under the car and cut the wires to the starter and took the starter so i bought another starter...
Both red wires go to the bigger post on the starter. The purple goes to the small post. There should be 2 big post, make sure the red wires go to the one that has nothing else on it cause the other is the ground.
Oct 17, 2014 | Cars & Trucks
Sorry for the lack of info The starter is new, disconnected the battery replaced the starter ad when the battery was connected the starter starts turning with out the ignition on but not engaging. The...
Well, if your starter starts to turn when you hook the battery cable up, then you have hooked the cable to the wrong post on the starter. You have two large posts and one small post on the starter solenoid, the battery cable goes on the large post that has nothing else hooked to it. The other large post should have a large braided cable going into the starter motor housing. If the starter still will not turn the engine over when it is wired correctly then you will need to look closer at the flywheel ring gear.
Sep 06, 2014 | 2007 Toyota Tundra
Putting starter back on vechicle need help with wiring
LOOKING AT STARTER WIRES.BATTERY CABLE POSITIVE CABLE GOES TO STARTER SOLENOID POSITIVE POST TERMINAL THAT IS THE LARGE STUD IN THE STARTER SOLENOID.. THE OTHER TWO RED WIRES WITH LARGE RING TERMINALS ALSO GOES TO THE STARTER SOLENOID POSITIVE POST TERMINAL.THE PURPLE WIRE WITH SMALL RING TERMINAL GOES TO S OR SWITCH POST TERMINAL.ON STARTER SOLENOID LOOK AT THE STARTER SOLENOID YOU WILL SEE LETTERS R AND S ON SOLENOID THE PURPLE WIRES WITH SMALL RING TERMINAL GOES TO S STUD TERMINAL ON STARTER SOLENOID.
May 26, 2011 | 1999 Oldsmobile Alero
Bought a new rebuilt starter for a 1996 chevy cavalier... My problem is one of the wires is black and has nothing on it so i dont know where too hook it up... i have a red wire with a big eye and a black...
Most likely goes on ignition side (small eye). If you connect it to large eye it will have power all the time. Small post (eye) only gets power when key is in start or run position. 2 big eye wires are input from battery positive & alternator feed.
Jun 30, 2010 | Cars & Trucks
Hello, i need instructions on how to wire a replacement solenoid in my 1995 ford ranger pickup, 4 cyl. The directions in the package only account for 3 wires and i have 4 wires going to my origional...
Starter solenoid???? 2 large posts and 2 small posts on old one or 2 large and 1 small? the one large wire goes to the starter(rear post), all the others goes on the front post. little wire goes on the little post, if the old one has 4 posts, then you have the wrong solenoid.
Oct 21, 2009 | 1995 Ford Ranger Supercab
Need pictures or exlanation of how to install a starter relay for
It's just an old Chevy starter! On that round starter solenoid, you will see two or three posts. One thick copper post, and one or two small
steel ones. The thick copper post you can't miss. It's about as thick as your little finger. The one, or two, small terminals, (Posts), are the thickness of a ball point pin refill.
You should have the Positive cable that comes down from the battery, connected to the thick post. There should -> also be two or three wires in a small wire loom, that connect to this post. This small wire loom will have a metal round terminal, that has a hole in it, large enough to go over this post. The battery cable goes on first, then this small wire loom terminal. Then a lock washer, and a brass nut.
If you have a solenoid with two small terminals, in the solenoid itself, next to the small posts, you may see -> ST,
and -> R. There should be a single wire, that comes down out of a wiring harness. It will have a round metal terminal end on it, and a hole in it, just large enough to slip over the small post. You want to connect it to the post with -> ST
All that is going on here, is that the solenoid is a magnetic switch.
If it wasn't present, you would have a thick wire, like that battery cable, going up to your ignition key switch. Instead you have a real small wire going to it.
Electricity for other circuits, like the lighting circuit, heat and air circuit, and so on, get their supply from the large solenoid post, also. That's what that two, or three wire, harness is for.
ST stands for Start. This is the Start side of the solenoid. R stands for Resistor. There was a wire used to connect to this small post, and it led up to a resistor mounted on the firewall, of older cars. These cars used a distributor with points in it. A wire went from the resistor over to the distributor.
Your solenoid may not have two small posts. It may just have one, with ST next to it, Or -> S
May 18, 2009 | 1996 Chevrolet Cavalier
Wiring for a 1993 ford f150 starter
not correct
the negative wire should be attached under the head of a mounting bolt for the starter
the circuit is that the power goes into the positive terminal ( big terminal) through the solenoid when activated out the second big terminal through the fields and armature to ground
the power to activate the solenoid is either from a power wire from the ignition switch to a small terminal on the solenoid through the windings to ground that activates the solenoid and closes a set of contacts in the solenoid to allow the power across the 2 big terminals
Jul 11, 2017 | 1988 Ford F 150
Wireing on starter, 1997 chevy blazer 4x4.
this just jumps to the other large post (battery power) on the starter -jeff please rate
Jun 30, 2008 | 1997 Chevrolet Blazer
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
