Question about GE JE1540 Microwave Oven
Oven comes on when the door is opened. The control panel CLEAR/OFF button does not respond to turn the oven off with the door opened. The only way to stop the oven is to close the door.
  • 999 Answers
One or more door switches is bad. Recommend replace all and have professionally aligned.
Eric
Posted on Jun 09, 2010
Microwave comes on in cooking mode with the door closed when plugged in. The Clear/Off button does not turn off and we have to open the door to turn off.
I have a hunch the microwave panel is going into Child lock mode and preventing you from operating the clear/off function. Not sure which is the middle switch that you replaced. I would suggest you give the panel a good wipe with a clean damp cloth to remove all grime etc. Before selecting the start/pause button press the Clear/off button for 3 secs and see if the L (lock) shows up on the display. Next press again for 3 secs to see if L goes away.
This way you have confirmed the panel is not in lock mode before you start next operation. Provide your observations in the comments section so that I can assess what the next step should be.
Aug 14, 2014 | General Electric PEM31SMSS 800 Watts...
When microwave finishes light doesn't come on when door open; display keeps reading "food ready" after food is taken out--have to push the "clear/off" button to make "food ready" display go away; counter...
Shorted switch in the door latch assembly.wihout the full model number I can't tell how to get to it, but usually one needs to remove top grille, remove screw holding the control panel, remove control panel. Good luck.
Nov 26, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
14 month old LG Microwave. The control panel is
Very common , You need to replace the switch membrain , this is the entire touch pad , they are not to much $ , and you should find it easy online.
Phil
Apr 10, 2009 | LG LMV1630 Convection/Microwave Oven
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot open the door Dacor Model DMO24S
You will need to remove the outer wrapper, then separate the control panel from the microwave by removing the screw and then lifting the panel up and away. If you disconnect any wires, be sure to mark them, make a diagram or take photos first so you get them all back exactly where they were. The attached photo shows the area where two locking tabs are located. They must be gently pushed in to allow the door open button and spring to be removed. The door open button is part # 86778 (if your oven is black or stainless, part # 86778 if your color is arctic) and it can be obtained from a Dacor distributor such as http://www.apdepot.com This should be the same as a Sharp model R330BK (black model) and you can order that door open button from Tritronics. It is part # JBTN-B088WRF0 and they are at http://www.wehaveparts.com
Dec 13, 2006 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
110 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
