Question about Sewing Machines
I have an old Singer (1963). the top thread keeps breaking. Help!
  • margaretbowm Jun 07, 2010
    I am using a fine cotton thread for both bobbin and top threading.
    I don't think my answer was sent (I have anew computer)..I am using a fine cotton thread - both for bobbin and top threading.
  • 135 Answers
Something is up wit the top tension...don't try to fix it yourself, take it to a repair shop, you'll be glad you did.
Posted on Jun 24, 2010
Singer 2273
Install a brand new needle (make sure it is compatible with the thread and fabric). Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the top tension to the midway point and retest your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
AVOID old or bargain bin thread.
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
Sewing Machine Thread Keeps Breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Why is my thread breaking
Mar 20, 2018 | Singer Sewing Machines
I have a Quantum CXL Singer sewing machine and the thread keeps breaking. It will make about 3 stitches and breaks. It is breaking in the same place.
Make sure the thread coming off the spool is not wrapping around the spool spindle. Install a brand new needle. Remove ALL the thread from the machine. Clean bobbin area of any dust, lint, threads. Set upper tension to the midpoint. RAISE the presser foot and then totally re-thread the machine from beginning to end verifying the sequence is correct. Test.
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Oct 06, 2015 | Singer Sewing Machines
My singer 8500q keeps coming up with a 06 error (top thread breaking) buts it's not breaking. Also now has a tension problem that won't adjust. Any suggestions?
Other manufacturers call this the Thread Out Sensor. You don't need it as you're watching the machine all the time anyway.
Take it in for a Service and have them unplug that sensor.
Mar 08, 2015 | Singer Sewing Machines
What should I do if the top thread keeps breaking off?
Reduce tension. Perhaps it is very thin - or cheap thread? Or very old thread?
If so, replace with good thread.
If that is OK, them try to lessen the tension.
Moses
Sep 01, 2014 | Singer 1120 Mechanical Sewing Machine
Pinterest everything
I would change the needle because sometimes there is a burr inside the eye of the needle. Now when you rethread, make sure that your presser foot is up, and then pull on the thread to make sure that the thread is seated in all of the guides.
Jan 16, 2018 | Singer 7462 Mechanical Sewing Machine
Top thread keeps snapping on consew 230b
Top thread snapping. Do you have an idea of there it is breaking?
First I would check the needle throat plate and needle. If you have stab marks on your needle plate, examine it closely for a crack. (get out the magnifying glass or jewelers loop) I recently fixed a problem I had with an old singer that kept breaking the top thread by replacing the needle plate. The old needle plate was so damaged it had actually made a knife edge which consistently cut the thread right at that location.
Change your needle and make sure it is the proper size for your thread. Too narrow of an eye can shred the thread causing it to break.
Next, check anything along your threading process that could be catching or snagging the thread. A worn or chipped thread guide can be a real problem.
Also make sure your thread hasn't dropped down below your thread cones and wrapped around the thread spindle. This would cause extra tension that might not be readily apparent.
Good luck
Aug 15, 2012 | Consew Sewing Machines
Top thread keeps breaking
i have a singer sewing machhine that keeps breaking the top thread!!! it is not computerized!!! can you help me?
Apr 27, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
