Question about Whirlpool Duet GHW9150P Front Load Washer
What does the control locked light mean and why won't the door shut?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 07, 2010
Ariston AVXL 129 4H lit up and not starting
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line.
May 02, 2013 | Washing Machines
2008 GMC Sierra pickup. Driving and all of a sudden it shut off then turned back on; the doors unlocked then locked again. Now it won't do anything. Checked the oil and it was empty - no oil at
Running with no oil is death for the motor ( Seized). When the alternator stopped working because the engine stopped the door lock control opened the door locks as it said you were below the required speed to have them locked
Mar 31, 2013 | 2008 GMC Sierra 1500
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer won't stay running error code DS
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
Oct 16, 2012 | Washing Machines
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
44082 is the model #
he code "dr" means the control doesn't see the door switch being closed.This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced.
Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem.
The switch can be obtained from the following link: Sears PartsDirect . Remember to unplug the washer first before attempting to change the switch.
The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
I hope this information helps you resolve this problem but submit another question with any additional details for further assistance.
Helpful attachments:
The code "dr" means the control doesn't see the door switch being closed. This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced. Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem. The switch can be obtained from the following link: [Sears PartsDirect |www.searspartsdirect.com] . Remember to unplug the washer first before attempting to change the switch. The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
Apr 15, 2010 | Kenmore 43042 Front Load Washer
GE JGBP80 oven shuts off and the locked door light flashes
That's awesome! I just found this site on Christmas day minutes away from family arriving and I had exhausted the manual for help. Under the troubleshooting section of the manual it lists "door Locked" light blinking as a problem with the only solution being - "shut the door." With three dishes in the oven that didn't help!
I took the advice of the site and wiggled the actual door lock on the inside of the oven and that didn't work right away either.
I had to trick the oven into thinking the door was shut by pressing the sensor on the right hand side in and then turn on the oven cleaning cycle with the sensor held down. After the lock activated and moved across with the door open, I had to hold down the door unlock feature and wiggle the lock as it unlocked. A little more complicated, but none the less it worked!
It must be a sensor inside the locking mechanism that isn't reading the lock being open - or something...
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
When you start a cycle the washer fills then turns then sounds as though its trying to empty the door lock light flashes and 2 other display lights flash
It means your door is not shutting or latching
Check for debris and nothing stopping it from shutting
If not replace door latch(some parts lists call it door switch)
its most likely not actuating so it wont advance to the next part of cycle.
if not latch could be bad control board, id try latch first is cheaper and more common
May 02, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
