Question about Ovens
Hi I'm still having problems with our Blanco oven, it is model number bsm901sse and the fan is not turning at the back of the oven and the oven is not heating up, I have been told it is a fuse but can't find one in it then was told it was the element at the back of the oven but are having probems getting to it, can someone please help me I'm really confused, thanks in advance
  • manz80 Jun 07, 2010
    just wanting one more person's advice, thanks
  • manz80 Jun 09, 2010
    Thank you so much for your help, all is working now, very much appreciate it
    Brigadier General:
  • 3,513 Answers
The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. However replacing the element is suggested.
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 07, 2010
    Hi would that also cause the oven not to heat up? thanks for your help on this
  • 2,272 Answers
The base element is concealed beneath the bottom of the oven to make the oven easier to clean and contribute to better access into the oven.
The top element is at the upper side of the oven.And the fan is on the side of the oven.
Working volume of the oven 52 L
Electrical features-
Input voltage-230-240v 50hz
Grill element-1600w
Upper element-800w
Lower element-1000w
Lighting bulb-15w
Oven fan-30w
Cooling fan-25w
Max. power-1900w
All powers are in watts.
Check the elements and fan watts by meter.if its low then mentioned then that particular part is to be replaced.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Find the model number on a 2010 Blanco stainless steel wall oven
The number has to be somewhere on the unit. Find it.
Nov 22, 2015 | Blanco Ovens
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
Jan 28, 2015 | Blanco Ovens
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
How do i replace bottom element in blanco oven model bso632
Hi Ron.
Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
Dec 19, 2011 | Ovens
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
Oven Problem
http://www.blanco-australia.com/IgnitionSuite/uploads/docs/BSO632.pdf
This link should take you to the manual- if not, go to www.blanco-australia.com, link on "customer service", select "user manuals", and scroll thru to your model BSO632
Jan 15, 2010 | Bosch Ovens
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
