Question about Toshiba Satellite A215-S4747 Notebook
Laptop won't boot
Laptop (Toshiba Satellite A215) won't boot but the power led is light on.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 46 Answers
Press f12
Posted on Jun 09, 2010
And that's the only issue your Laptop has? No messages that pop up or displayed as you try and run them? Vista OS, right? At this stage all I can think of another program is stopping them like Windows Defender? is that on your system and running/enabled if so look into it to see if it's blocking restricting applications running.
May 03, 2013 | Toshiba Satellite A215-S7422 Notebook
Laptop won't boot up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. Toshiba Satellite A215 adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Feb 20, 2013 | Toshiba Satellite A215-S7444 Notebook
Toshiba C655s5120 black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 13, 2012 | Toshiba Satellite A215-S7437 Notebook
Satellite a215-s4757 won't boot after reassembly
BAD MISTAKE.NOW YOU WILL NEED TO OPEN IT AGAIN AND RESET ALL THE HARDWARE.
Apr 11, 2012 | Toshiba Satellite A215-S5822 Laptop
My toshiba satellite laptop keyboard just quit and won't work, totally frozen and nothing appears as i type. pls help toshiba satellite laptop A215-S5837, windows 7, vista
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
May 12, 2011 | Toshiba Satellite A215-S5837 Notebook
Toshiba satellite a215 loses connection with power cord
The fault could be the adapter plug (a broken wire at the plug) that connects into the laptop or a faulty power socket on the laptop. In most cases it is the power socket on the laptop, it could be just a dry solder joint in the circuit board where the power socket is soldered on the motherboard or the power socket is faulty and therefore needs to be replaced.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 06, 2010 | Toshiba Satellite A215-S4747 Notebook
The laptop wont boot up.
remove battery and test it if doesnt work try to test it by another power adapter.
Aug 05, 2009 | Toshiba Satellite A215-S5822 Laptop
Toshiba satillite A215 won't boot up. No sounds from drive, fan, nada, zip. worked fine yesterday.
connect to the external monitor through the vga port of the laptop, check the display, if the display is there then its the problem of your laptop screen
like the soluton or not rate it please
Oct 17, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A215-S4747 Notebook Logo
391 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
