Question about Amcor PLM-14000E Portable Air Conditioner
Not cooling system running but not cooling, have it all the way down to 64 degree.
    Problem Solver:
  • 6 Answers
Try another site, you get no good answers here for this units issues
Posted on Jul 31, 2010
  • 523 Answers
Leak
Posted on Jun 07, 2010
Refrigerator not cooling properly
Sounds like the motor. If the motor isn't running properly or at all then the cooling systems are affected and the fridge runs warm.
Oct 19, 2015 | Refrigerators
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
HP DV7-3085DX Shut down at 120 degrees C
No solution, but that is really hot. Hot enough to start frying other components. Eventually it will.
Nov 28, 2012 | Computers & Internet
What is the max. temp. for 2004 4x4 trailblazer
Depends.
A normal cooling system runs between 195 degrees when the thermostat opens, to 230 degrees when the cooling fan kicks on.
If you are experiencing air temps over 90 degrees, the cooling system could run at 210 or higher.
Idling and moving make a difference too.
Jul 10, 2012 | 2004 Chevrolet TrailBlazer
I replaced the compressor on my refrigerator. There were no tags as to how much freon the system takes. So I added enough to bring the low side to 72 psi w/ a cabinet temp of 70 degrees. The high side...
**** boy. 72 psi on the low side? It ain't an air conditioner. The low side should be never over 5 PSI. The whole system holds only arounf 4 ounces. What were ya thankin? LOL WOW you will be lucky if the reed valves ain't blown in the new compressor. Go ahead and evacuate the system. Pull that ****** down to as close to negative 30 as you can and then shut her down. Just crack open the freon a hair and let it SLOWL:Y build to no more than 5PSI on the low side.
Feb 17, 2011 | Refrigerators
Our refrigerator is intermittently warming up (up to 37 degrees in the freezer & 64 degrees in the fridge) and then cooling down again. There is a clicking noise that has gotten more persistent. The...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Frigidaire FRS3R5EMB Side by Side...
My refrigeraton is not getting as cold as it should,bot the freezer is.Refrig temp 64 degrees.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Samsung RB2155SH Bottom Freezer...
Temperature hand randomly goes up ad down
I presume you are referring to the gauge, That being said, it sounds to me like you have a air pocket in the cooling system. Check your coolant level (after it has cooled down), and run it for a few minutes with the cap off to burp the system if it was low.
Feb 18, 2010 | 1998 Cadillac Seville
Dual zone Danby Wine Refrigerator. Sounds okay running. Both areas now cool to only 62-64 degrees.
adjust the thermostat all the way to the coolest position and observe it for 24 hours
if it is still 62-64 degrees, then something is wrong. observe what is happening with the unit. is the compressor running, is there a fan which could not be running? or anything that you think is not right.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Refrigerators
Amcor PLM-14000E Portable Air Conditioner Logo
256 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
