Question about Video Game Consoles & Games
Three red flashing lights and once when it tried to load error e71
    Sergeant:
    Novelist:
  • 166 Answers
Hello there, this is a possible dashboard failed update. You can attempt to fix the problem yourself by doing the following:
With the console off, press and hold the sync up button (the small white one)
While holding the sync button press the power button to turn on the console
Continue to hold the sync button until the Console has booted up completely.
During the boot process the console should clear any failed updates, allowing you to use it normally.
If this fails to work then you need to contact microsoft xbox support.
Hope this helps.
Posted on Apr 10, 2008
Sometimes the console will not load to the screen where the big (xbox360) icon, the lights around the on/off button flash profusely and it seems as though the screen has frozen. if the loading gets past...
Those are common error on the XBox 360, after some extended use. You can try to send it to be repaired, and if it happens again, consider the purchase of a newer model.
Mar 01, 2011 | Microsoft Xbox 360 Console
I have an xbox 360 that pops up with the 3 red lights on the front and every now and then the e71 error. How do I fix this problem myself?
Nobody is 100% sure what causes this error but it Most likely relates to dashboard and console updates. Also, the problem appears to arise from gamers incorrectly flashing their hardware or doing botched firmware hacks which then prevent the system from functioning correctly.
Have you recently updated your Xbox 360 in anyway, or have you (or anyone else) attempted some form of firmware hack or flash? If so, this is probably the cause of the e71 code on your Xbox, however, it could also be completely random. If you call microsoft they will most likely tell you to9 just reset but that is only a temporary fix and you still have the problem of annoying freezes which will get worse and worse. Fixing the Xbox e71 is quite tricky. First try these methods,
1) switch off the console. With the console switched off, press and hold the sync button (the small white button that is used to search for wireless connections). While holding the sync button, switch on the console by pressing the power button and do not release hold of the sync button until the console is fully booted up. During the booting up of the console, any failed updates will be cleared allowing the console to run normally once again and thus eliminating the xbox 360 e71 error.
Another similar way is to
2)Hold the wireless connection button on your controller down with the 360 off. It's the little white button between the shoulder buttons. It's what you used to set up your wireless controller with your 360. While still holding the button, hit the XBOX logo on the controller to turn on the XBOX. Do not let go of the white button. After it's fully started up, you can let go. this reverts you back to your last update.
Or if nothing else seems to work you could try completely resetting your Xbox 360. To do this,
3) First enter the dashboard, go to the right-most column, go and press "Initial Set Up" then follow the instructions on screen. If you cannot access this screen due to the e71 error on your Xbox 360, you can try holding the "Y" button on your controller as you switch the console on. This will enter the same process, and restore default factory settings. However, there is still a chance that this might not work.
There are guides available online for less than $30 if you cant seem to get it fixed but make sure you get one that explains all errors as most only tell about the red ring of death.
Hope this helps
Nov 29, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
My ps3 won't load the discs...
Hi, if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Thanks and take
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
E71 system error has appeared on screen with one red ring lit. Does anyone know how to resolve as my machine is out of warranty? Thanks in advance Firefly
the way to get around this is to contact Xbox support via phone/email and tell them you have three red lights on your console and your warranty will be automatically extended to 3years FREE and will be booked in for a FREE repair
Tel: 0800 469 9263
Jan 30, 2010 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
E71
the e71 error is somethink to do wiv the motherboard try and find the wesite that can give you a step by step guide on how to sort it ok but be careful of certian one some are fake ok
Jan 11, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Two Flashing Lights
it may be overheating depending on which 2 are flashing, which if its shutting itself down, im willing to bet thats what it is. make sure you've attached the heatsinks securely with the x clips and do yourself a favor and use some good thermal material like arctic silver. make sure the fan is securely plugged into the mainboard.
Aug 03, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
