Question about Weber Q Grill
Won't light properly or vary the flame
Took the BBQ to a Weber service shop and it worked perfectly for them!! They said to let the gas run on low pressure for 30 secs before cranking up the gas flow and trying to light it. I have tried everything. New tank, new hose, regulator worked perfectly in the service shop... get it home, hook it up and it spits and sputters with a very low flame and no amount of wiggling and jiggling makes any difference. I'm about ready to put it in the bin!
I can hear gas flowing on the 'start' section but it seems to stop almost immediately...
  • 494 Answers
You're probably turning the LP tank valve on too fast. Close the tank valve, disconnect it and reconnect it. Then very slowly turn on the tank valve. Make sure all your grill knobs are closed. Light one at a time and turn to low setting. After they are all lit, slowly turn up the heat on each as needed. Hope this helps. Douglas
Posted on Jun 07, 2010
Bought this grill in june/july. first tank worked perfect. tank went out while cooking. changed to new tank and lit her up. low flame and went out. looked at tank and found the valve and hose covered...
turn off gas at tank remove hose let it deforst , open all burners on bbq run out gas in line , turn off burners, reconnect tank turn on slow , check hose for leaks with washing up liqued and water mix make bubbles with this mix and brush over joints this will prove if you have a gas leak (hence the frosting ) if this is good no leak then you should be able to light burners , if this leaks then it could be a new hose.
Sep 24, 2011 | Weber Spirit SP-310 Propane Grill
Won't heat up higher than 300
open gas control taps on bbq let pressure out turn off taps reconnect tank turn gas back on
Jul 02, 2010 | Weber Genesis Silver B Grill
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
I just hooked up an LPG bottle and hose to my Weber Q, and when I light it, the flame is very weak. In fact, the flame extinguishes after about 10 seconds. I can't seem to get the proper flow of gas to...
if using the adapter hose for large tank weber has had problems with hose call weber and get new one or call bbq galore and ask for a 4ft. adapter hose 214-696-0030
Aug 10, 2009 | Weber Q Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Mar 14, 2009 | Weber Genesis Silver B Grill
Weber gas bbq
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Oct 26, 2008 | Grilling
My weber Baby Q grill has a low flame.
Agree with rjmbridge. I called the Weber support people and was told that there is a built in safety feature on the regulator that will cause the flame to burn at a low setting if the gas within the extension tube to the large tank and regulator is not allowed enough time to equalize. They suggested turning on the gas from the tank very slowly, allow about 2 minutes with the temperature control knob turned off, then turn the temp knob on and light. This worked for me.
May 27, 2008 | Weber Baby Q Grill
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Weber Q Grill Logo
667 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
