Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Fridge beeping Sorry i do not know the model of my fisher and paykel fridge as i bought it second hand and didnt get a book with it. it has active smart written on the inside and has the fridge up top freezer down bottom. for the past three nights the unit has started beeping and always in the middle of the night. I though the on of the doors was open but they werent, and it stopped once i pressed the buttons a few times. and I also noticed that the grren lights were flashing. hope that is helpful.
  • 30 Answers
The beeping is an alarm certain lights on the display will be flashing when it is beeping record which lights are flashing this idicates a fault code then post your results and i will tell you what the fault code is and what the problem is likely to be :)
Posted on Jun 08, 2010
Fisher & Paykel fridge the water dispenser on the front of fridge is locked how do you unlock it.?
Hello Patti Emelson,
Let's say... (for example)
Your model number is E522BLXU...
on that model... (Fisher & Paykel)
Page 10 of those
instructions
says of manualslib.com (URL link below)
Dispense LOCK
This mode disables the water dispensing pad & prevents water
from being dispensed.
To activate this mode, press the MENU and MEASURED FILL
keys together for two (2) seconds...
Of course the precise buttons could vary... WHICH is why
putting in TOUR MODEL NUMBER is important for
such questions ...
Reference
Fisher Paykel E522BLXU Service Manual Dispenser Lock Key Presses measured...
Hope this helps
Carnac the Magnificent
Oct 21, 2017 | Fisher Refrigerators
My fisher paykel model number# rf170adx4, serial # rhg755331 fridge beeps every time we open the door (not leaving it open)! It's a brand new fridge.
It is probably just a warning beep to let you know the door is open. It should stop when the door is closed. There may be an override setting to cancel this. Have a look in the Owners book to see if you can reset this or check with your F and P Customer service centre and ask.
Nov 19, 2016 | Fisher Refrigerators
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
Why does my fisher and paykel active smart fridge/freezer keeps beeping when I open fridge? As if the fridge has been open for a long time?
Does the beeping start immediately or does it follow the designed timing as stated on page 12 of the manual? You would have to check with the manufacturer to see if the feature can be disabled. Page 12 of Fisher Paykel Refrigeration User Guide ManualsOnline com
Mar 08, 2015 | Fisher and Paykel Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
What do I do when my fridge, is beeping constantly and won't go into sabbath mode
I don't know why it would be beeping. Some new feature I don't know about, and I don't know what a sabbath mode it.
Sorry..................
Aug 07, 2014 | Fisher and Paykel Refrigerators
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
1,398 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
