Question about Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red
Stopped recieving music through the headphones but continue to get calls. Any ideas
    President:
  • 1,118 Answers
You could try re-pair it again. On your device, remove the partnership with the headst. Then, press and hold the power button for more than 3 seconds, until the led is solidly lit. It is in pairing mode now. Make your device search for new devices again. After the S9 appears on the device's screen, select it and make it connect. If a pairing code (or PIN, or passkey) is requested. enter '0000' (four zeros).
Hope it works for you.
Regards, Carlos
Posted on Jun 07, 2010
Hi, I am unable to answer call with headphones
i think ur headphone has damaged with a broken cable or any small parts of materials. It will be solved by any reparer but not be good. So plz take a new one. Thank u.
Sep 27, 2013 | Audio Players & Recorders
Connect laptop to technics av sa-ex400 reciever
you will have to buy an 1/8" stereo jack to rca plug....insert the headphone jack into the headphone out of laptop and plug in to any input of choice in the back of the receiver (i.e. aux, video in, cd)...play some music or whatever on laptop and turn your reciever to that input....
Jun 22, 2013 | Audio Players & Recorders
I recieved a message alert while listening to my music through my headphones and the player stopped. Now the player shows its running but theres no sound.
when listening to music and alert comes through the music will always pause, so that you can check the score, read alert or whatever........ to continue music just press play........ in your case shut it off and restart (boot it up again)
Mar 29, 2011 | HTC Inspire 4G Smartphone
My turtle beach X1 left headphone and microphone has stopped working have you got any ideas why or somewere that could fix it ? Many thanks
Why don't you contact Turtle Beach directly? You probably broke a cable or something. They have replacement parts on their website.
Actually, to test the headphones, plug in the green jack and USB to your PC and listen to music. If both speakers work, then the headset is fine.
Apr 06, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
How to configure bluetooth headphone to play music?
This phonr doesnt support A2DP profiles, so u cant play songs throgh bluetooth headset
Sep 03, 2009 | Samsung SGH-J600 Cellular Phone
My nokia 6233 has a picture of some headphones on the display and i cannot hear anything when ringing out or recieving a call?
Some earfones are only designed to listen to the features of the fone like the radio and music player, while others are designed to answer calls and listen to music. You might have to purchase one for yourself.
Aug 24, 2009 | Nokia 6233 Cellular Phone
Cant recieve or make calls from my headset.
what headset are u using? i presume its the 's9', most connection problems are solved by disconnecting the headphone and then reconnect it.
or go to ur bluetooth devices on ur computer, and click on the device then properties, then services then, select all boxes. remember to apply the changes.
good luck
Dec 30, 2008 | Motorola Mobility S9 Headphones
Logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Dec 17, 2008 | Logitech FreePulse Wireless Consumer...
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red Logo
198 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
