Question about Kenmore 24032\24036 Top Load Washer
My washer has a nasty funky smell-the machine works well, but I can't get rid of the smell. What do I do? I tried clorox and detergent and hot water wash x 2 - no luck!! Help
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
When our washer had some major problems, we ended up tearing it apart a couple of times (including pulling the entire tub assembly). What we found was a major amount of gunk that built up over a number of years. It's possible that (depending on the age of your washer) you have the same problem.
In order to pull the tub to get under and clean it, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Jun 07, 2010
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Musty smell
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very, very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap ****/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called
"TIDE WASHING MACHINE CLEANER" which is very effective.
Service manual and more can be found at this BLOG of mine
Jun 12, 2012 | LG Washing Machines
How do I get rid of a mildew odor in the Whirlpool Duet front loader?
bleach and bleach and bleach and bleach!!!!! also i notice more of a smell in washers when people only use liquid detergent and too much of it.
Tip: leave door open after every wash
clean with bleach and hot water regularly once a month
with no clothes on a normal cycle
alternate liquid detergent and powder (yes powder comes HE)
only use HE detergent
try these things and you will find your washer smelling like new again. but tthe trick is BLEACH and a lot of it. once you get a smell it takes a long time to get rid of it.
good luck and let me know if this helps
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Foul odor when I start a load of laundry
Obviously this problem exists on this manufactured machine (Cabrio). It has to do with the design of the machine and the HE detergent required to be used. We are on city water and the smell is sewage gas. Hence, do your whites last with lots of Clorox/bleach, cause the detergent isn't strong enoug to kill the bacteria growing in the pipes. That being said, P
Jul 12, 2009 | Whirlpool Cabrio WTW6600SBK
Sewer smelling towels!!! Towels are the worst, other clothes are not great, but not as bad. For the past year I have endured this horrible smell. I've just had it!!! I have done the clorox washings many...
Put a cup of powdered dishwashing detergent in the barrel ie. Sunlight or Palmolive. Place 1 cup of bleach in the soap dispenser. Run on a quick cycle with HOT/HOT and run complete cycle. This does help and don't forget to clean the filter on the lower part of the unit.
Jul 10, 2009 | LG WM-2277HW Front Load Washer
The machine smells moldy even after I ran clorox through it.
keep doing it. it is going to take more than one cycle of cleaning to get rid of the smell. They sell products to help clean out odors of washers. These are some products you can use Washer Magic or Affresh tablets. If you have a Sears near you they sell it. I would use hot water and bleach one cycle then do a Affresh tablet. See how it goes
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Musty stale smell
HI thanks for your question. ALL front load washers have the same problem.MY solution every wash use 1 cup of vinegar in time will solve the problem. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | LG WM1814CW Front Load Washer
Awful smell in drum of washing machine
My friend told me of someone who researched this problem, and it is because we are using liquid detergent. Switch to a granular high efficiency detergent. Before you start using it, you must run through a mixture of about one cup Clorox and two cups vinegar through the washer, using the Sanitary setting. I am actually on-line now trying to research the exact proportions of Clorox and vinegar when I ran across your problem.
Nov 03, 2007 | Kenmore 44042 Front Load Washer
Smell in washer
What kind of smell is it?  If I can guess, I think it may be a musty or "locker-room" (sorry for bad memories) smell.  I have found that sometimes a change in detergent (or sometimes the same detergent you have been using for years) can cause build up and retain that musty smell.  I had to actually remove a inner basket completely and wash out both inner and outer drums to get rid of the funky smell.  She had used the same detergent for years.  Do you wash a lot of clothes in cold water?  This could also make the situation worse.  Try running a full empty load on hot with a bunch of bleach through the wash cycle, then stop the unit for a bit and let it soak and see if it clears up.  Also, try changing detergents and use a HE type soap.  HE causes very little sudding action, which in turn will stop the build up.  If this doesnt work, you may have to remove the inner tub and clean out both baskets (a lot of time, and need a special wrench, unless you know how to work it off).  Let me know if this helps any.   Jim
Oct 17, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
