Question about Samsung SyncMaster 2233SW Monitor
Goes to black after one second
Image appears at power on then goes to black after about one second
  • lcjj Jun 07, 2010
    Actually, this Samsung 2233SW has been tried now on three different PC's with the result the same on each. In fact, on this XP SP3 PC I even did a fresh driver download and install to assure it has the most recent. Still same thing. Each time the monitor gets a "new" signal, such as the laptop function change to turn on/off the video to the VGA port, the monitor lights up with the correct screen but then immediately goes out. Again, three different computers, same symptom on each.
  • 11,361 Answers
Here are pictures of failed SAMSUNG monitors due to bad caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
This monitor should be under warranty.
Posted on Jun 09, 2010
  • 732 Answers
Lcjj, Is unit black and blank screen? or just black screen? do flashlight test after pc boots-up. Can you see images and icons on desktop screen with aid of flashlight?? How old is the unit? Is unit out of warranty? Have you been to YOUTUBE to check-out DIY video clips on troubleshooting and the low cost DIY repairs being done to CCFL back-lit lcd monitors? Your monitor's problem not new one!! Try some of these web sites: www.ccl-la.com/badcaps.htm and www.lcdrepair.us/files/dell_1800fp_power_supply_installation_instructions.pdf and www.badcaps.net and www.lcdparts.net and www.ccfldirect.com and after you finish with that you can start reading the fixya PROFILES of "buddymc" , "budmrtn" , "12fixlouie" In short... you will do one of these four things. 1. DIY refurbishment. 2. Contract out refurbishment work. 3. Trade in unit for new. 4. Do a cash+old swap out with Samsung if they are doing a "just out of warranty" swap for "premature failed" units. Do your test and research first. Then make decision on what to do. Good luck. 12fixlouie
When i turn on the monitor , the indicator light on the power will on .And the image or signal will appear (coming from the computer) for a couple of seconds then it will goes blank or black. But the...
What is the model number? Yes lamps do go bad (blackened ends) or bad soldering works on the lamps. See my lamps album. You need lamp tester and inverter tester to verify.
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 16, 2011 | ViewSonic Computers & Internet
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Monitor comes on but then shuts off in about a second
Try reducing the resolution (boot at safe mode)
Stelios.
Feb 22, 2010 | Dell UltraSharp 1908FP Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Image displayed for 2 seconds after powering monitor on
The problem could be the CCFL lamp, especially if the image has a pink hue.
Check LCD Parts for service, parts and DIY info. use this link :-
www.lcdparts.net
Sep 20, 2009 | HP f2105 21" LCD Monitor
Monitor image comes up, then blacks out, power still on
Hello David,
This is very common problem and is heat/age related, but It can happen to monitors that are no more than a year old. It is usually bad capacitors on on power inverter board. I just fixed two monitors with this problem. This problem is common across all brands. Look for several radial capacitors in a cluster on the power inverter board. If some are bulging or have a slightly domed top, they are the ones that are bad. I usually replace all the capacitors in this small cluster because some may be marginal. This is easy to do if you have a bit of electronics skill.
Dec 27, 2008 | Rosewill MNTR |LCD 19' 8MS DVI R912E...
Screen goes black
Hai,
Do you see any dull image on the screen ?
If yes the inverter Card/Backlight of the screen is having problem.
Regards,
Aby
Dec 22, 2007 | Rosewill R900J 19" Flat Panel LCD Monitor
D40X LCD: Initial display time?
In your custom settings no 15 Auto Timers you can set the time.
Brian Mason
Dec 08, 2007 | Nikon D40x Digital Camera
32" Trinitron warms up picture goes black
You need to call for service now that the unit still turns on,the problem will become expensive if you try to use it like this,right now the set might have loose conections in the power supply,horizontal driver transformer.ETC.Be safe and call a service tech.
Sep 25, 2006 | RCA P46924 46" Rear Projection Television
Samsung SyncMaster 2233SW Monitor Logo
625 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
