Question about Whirlpool Duet GHW9150P Front Load Washer
Washer was almost through cycle and is flashing F2. Clothes are saturated and appear to have not been through final spin cycle. What could be the problem?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 07, 2010
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Washer not draining
Probably the pump filter needs cleaning.
It should be located at the bottom front of washer behind drop down cover, turn anti-clockwise to remove and clean.
May 04, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
