Question about Toshiba 53H71 53 in. Rear Projection Television
Where can i find a convergence chips (ic's) 2pcs for my tv?
    Brigadier General:
  • 8,619 Answers
Hi
Thanksfor using FixYa. You can buy the convergence chips from this link; also if youwant you can buy repair kit which comes with complete installation and parts. Pleasedo rate the solution if the issue is resolved or post a comment for furtherassistance.
Thanks
Rylee
Posted on Jun 07, 2010
Distorted picture and color
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
This set uses two of the STK-392-570 IC chips for this (convergence problem)
Local tv repairman will do this job if you have no experience of electronics stuff repair.
Dec 22, 2010 | Sony KP-51HW40 51" Rear Projection...
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
I have a PT51HX41C. The convergance is not working, and everything seems like 3D without the glasses. IC chips? How many? Where? Part number? Thanks in advance.
Ur tv nane and model,the convergence IC chips will be in that kit.U know how to solder right?Tries these websites.Tv Repair World.com or Ebay.com.
Sep 29, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Hitachi 50ux26b projection TV, the color lines separated...
It sounds like a convergence problem; either bad solder connections at one of the convergence Ic chips or a bad Ic. if this was helpful give me a vote----if one of the chips is now bad it will have to be replaced(usual thing is to replace all the convergence ic chips---most use two and a few 3.
Aug 12, 2009 | Televison & Video
The blu display on my sony 65" tv is arched, making the convergence adjustment in-effective.
its failure of Convergence Out IC chip and requires replacement.
TV has 2 IC chip in convergence circuit and I would recommend to replace both at same time.
Let me know exact model of Sony 65" TV to provide you more technical info.
Mar 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Toshiba 42H83 projection TV red convergence issue
the Convergence Ics are STK392-110 ICs you can get replacement Ics at the following link and they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 03, 2008 | Toshiba 42H83 42" Rear Projection...
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
240 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
