Question about Riccar and Simplcity Canister Vacuum Cleaner Deluxe Bare Surface Floor Brus
Cord is hot and vaccumn keeps running then shutting off and on
  • 438 Answers
Hi There,
May you kindly please clarify what type of vacuum cleaner that you have? The model number may be located at the bottom or the back of the vacuum cleaner, and this number will help me determine what the problem with your vacuum cleaner is. Please just use the comment section on this repair solution to answer. Thanks,
Posted on Jun 07, 2010
No power - vaccumn quit running
The motor is burned out or the brushes in the motor coil need to be replaced.
Sep 09, 2014 | Dyson DC28 Animal Upright Vacuum New DC 28...
Why does my vac keep shutting down
switch the vaccum on & try wiggling the cord at the plug & see if it stops when you tighten the cord and wriggle it at the plug. This will indicate faulty lead if it shuts dwn when you do this . I suspect problem could be in your pwr lead needs replacing as lead faulty.
to fix replace lead.
Jun 01, 2014 | Nilfisk Vacuums
Kirbyg4 shutting off while in use
First thing to check is cord to make sure no bad spots anywhere. If the bag emptor is not installed properly there is a switch that will not allow vacuum to run. There is another switch that is depressed when the power nozzle, hose or carpet cleaner is installed on the front of your Kirby. If the switch is not being depressed properly it can keep the vacuum from running.
Oct 26, 2013 | Hoover U5180-900 Vacuum
New vac no instuction manual . i need to vaccumn
No you do not need the filter to pick up glass. If you are vacuuming up dust/dirt then use the filter.
Jan 22, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Run cut off -run cut off every ten minutes
The TOC(thermal overload cutout) on the motor is getting too hot - thats why it keeps shutting off and starting again once its cooled, so make sure your filters are clean and they are no blockages in the hose or the brushbar compartment or any where else
Which dyson is it?
Aug 31, 2009 | Dyson Vacuums
Power cut out during cleaning
1 could have hit the thermal shut off. if it gets to hot they shut off, or it could be the cord some times they just go bad or it could be something else. Good Luck!
Jul 28, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Ran over cord and the vacuum shut down, won't
sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Dyson dc15 just shut off.
Most likely your machine has a blockage, has overheated, and the thermal cutout has operated. This will reset itself when the machine cools, which can take an hour or more. Unfortunately Dysons tend to run hot anyway, so it doesn't take too much restriction of the airflow to cause this problem. Check for obstructions (including filter that may need washing) before anything else. Good luck!
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums shuts off during use
 My guess is: Either a loose contact on the plug  or Intermittent electricial open  in the electric cord itself. To confirm. Try wiggling the cord and ends while running. If you find the place yo ucan either replace the cord or repair it.
Dec 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Riccar and Simplcity Canister Vacuum Cleaner Deluxe Bare Surface Floor Brus Logo
157 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
