I don't understand your system.On June 6 I posed a question re availability & identification of cartridge/needle combos for an old BRS turntable.A "diskham" sent a reply,but not an answer.He also mentioned a "link below" which I couldn't find. I then sent back comments pointing out the above,but have heard nothing since. What did I do wrong ? Herb Heiss
  • 1 more comment
  • David Dunn
    David Dunn Jun 07, 2010
    Link us to the original question so we can follow how it played out. I can find no hits for BRS. Do you mean BSR? Accuracy in the question will facilitate accuracy in the answer, especially with initials, acronyms and model numbers.
  • herbheiss Jun 07, 2010
    sorry yes it is BSR
    sorry -tes it is BSR
    Brigadier General:
  • 8,546 Answers
And the link to the original question (or a complete resubmission of it) is....???
Posted on Jun 07, 2010
Why don t airplanes have their own parachute?
Many of the current general aviation planes now come with a ballistic parachute from BRS.
Jan 04, 2017 | Aircrafts
I do not understand this search, because I have posed my problem several times and I have not received any help whats up? 99 chevy cavalier here is whats up. I changed the ignition switch cylinder and ...
This web site is a free chat room
No one works for FixYa & there is no info here
other than the people like you that google or
know the answers & choose to respond
No guarantee anyone will answer your questions
Aug 28, 2013 | Cars & Trucks
Zenith inteq iqb50m90w has no sound, hooked up cable box with component cables
To be honest I do not really understand clearly your issue so I will pose a few questions that might clear things for me up:
1. No sound from internal speakers.
2. Speakers have be checked and are not open, disconnected or switched to external or variable audio out only.
3 A DVD or similar connected to a rear video and audio input has no sound.
4. The set had sound when hooked to the bose system.
Do I understand correctly or did I miss something?
If all the above is correct the set has a audio output problem (old trick is put ear directly to a speaker and see if anything, a buzz, faint sound or nothing at all.)
Dec 04, 2012 | Zenith IQB50M90W 50" Rear Projection...
Have a 1974 RCA stereo model:VCY350 I'm not
To what kinde of AMPLIFIER is the table connected to?? does the AMP have a PHONO input??? if not what input you are using on your amplifier??? or is this an all in one (cabinet) system??? can't google the model I guess it's to old even for a 43 year old tech. like me ha! (I was only 6 in 1974)
More information pleas!!!
May 26, 2011 | RCA Audio Players & Recorders
I have a photosmart printer, bought in England, which requires HP 363 cartridges. Whilst in USA in June I enquired at a computer supplies store if they sold these. The assistant looked it up on the HP...
You have to regionalise your printer to work with the cartridges you have to put in the cartridge code into the printer and only HP technicians can do it and as your printer is OOW there will be a charge on this
Apr 30, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have a Zenih Allego table type stereo with 8 track, radio & turntable, but it has NO cartridge at all - just wires from the needle arm. It's supposed to play 78s, how can I find out which cartridge...
You will need a very old type of cartridge called CERAMIC CARTRIDGE or CRYSTAL CARTRIDGE. It has been discontinued. Today's Hi-Fi use magnetic cartridge. Check out this link below
http://www.kabusa.com/frameset.htm?/phoncart.htm
Mar 10, 2011 | Audio Players & Recorders
1993 rodeo not running no power to fuel pump
if there is no power to the fuel pump check relays and fuses....UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION Fig. 2: Underhood Fuse & Relay Panel Identification Courtesy of ISUZU MOTOR CO. Fusible Link Identification ? A - 80 Amp (1991-92 3.1L) ? A - 60 Amp Main-1 ? B - 30 Amp Main-2 ? C - 30 Amp (1993-94) ECM (3.2L) ? D - 30 Amp Condenser Fan (A/T Models) Relay Identification ? 1 - Headlight Relay ? 2 - A/C - Heater Relay ? 3 - Starter Relay ? 4 - A/C Compressor Relay ? 5 - Charge Relay ? 6 - Fuel Pump Relay ? 7 - ECM Relay ? 8 - Wiper Relay Fuse & Circuit Breaker Identification ? 1 - 15 Amp (1991) ECM, Fuel Injection System ? 1 - 15 Amp (1992-94 2.6L) ECM, Fuel Injection System ? 1 - 10 Amp (1992-94 3.1 & 3.2L) Heated Oxygen Sensor, Fuel Injection System ? 2 - 20 Amp (1991-92) Fuel Pump ? 2 - 20 Amp (1993-94 2.6L) Fuel Pump ? 2 - 15 Amp (1993-94 3.2L) Fuel Pump ? 3 - 10 Amp (1991) ? 3 - 15 Amp (1992-94) Turn Signal Lights, Hazard Warning Flasher Lights ? 4 - 10 Amp Horn, Door Locks ? 5 - Not Used (1991 3.1L) ? 5 - 10 Amp Charging System, Charge Warning Light WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. Page 1 of 2 FUSES & CIRCUIT BREAKERS -1994 Isuzu Rodeo LS? 6 - Not Used (1991) (1992-93 2.6L) ? 6 - 10 Amp (1992-94 3.1L & 3.2L) A/T Interlock System ? 6 - 10 Amp (1994 2.6L) Heated Oxygen Sensor, Fuel Injection System ? 7 - 20 Amp Heater/Air Conditioning Blower Controls ? 8 - 10 Amp Air Conditioner Compressor Controls ? 9 - 10 Amp Right Headlight ? 10 - 10 Amp Left Headlight © 2008 Mitchell Repair Information Co., LLC.
Underhood fuse block swap out relay #7 thats the ECM relay.
Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location.
Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
Mar 28, 2010 | 1993 Isuzu Rodeo
How do we find battery component on old Polaroid camera...
Each film cartridge contains a new battery. Every time you replace the film, you get a new battery.
Now the bad news...
As of June 2008, Polaroid no longer makes film. The last of what was produced is expiring in 10/2009.
The hopeful news...
Polaroid may be licensing other companies to manufacture film again (after 2009) and another group is hard at work trying to produce a similar film for these cameras (http:\\www.the-impossible-project.com). But don't expect any of this to be available any time soon.
Sep 24, 2009 | Polaroid Photography
Can i purchase a needle for the ION ITTUSB ?
Yes but it is not the needle you would buy (ah in the old days it was a needle) but a cartridge
The user manual available here gives you a little more detail.
It is sometimes possible to get the needle assembly for the more expesive cartridges but yoy would need to know the cartridge make and model for that.
If you unscrew the headshell locking ring on the tone arm you can remove the cartridge by pulling it out (hold the arm and the headshell doing this)
This would give you a better idea of the cartridge make and model and also allow you to see how it is mounted (2 screws) to the headshell.
If this information was useful please click
Aug 17, 2009 | ION Audio iTTUSB Turntable
Cannot remove old cartridge
steps for removing and replacing the toner cartridges:
-before removing the toner cartridges, disconnect the A/C power cable from the back of the system & remove the printer's top cover
-rotate the securing lever upward to unlock the toner cartridge
-lift the cartridge out of the chassis, each toner housing and cartridge is color-coded and labeled for easy identification of toner cartridge color locations
-just reverse the previous steps to replace the toner cartridges
Jul 09, 2009 | Dell 5110cn Laser Printer
 Grubhead
Grubhead
