Gateway GT5220 bios works no boot up
Gateway GT5220 bios works. If you enter the bios everything seems ok. However after exiting bios or just do.ng a normal boot the screen goes black. I dont believe the computer boots either . The power light is on and the fans are turning. I think it may be the video card(built into the MB.
  • vernonlilly Jun 08, 2010
    Thanks for such a fast reply. There are no error messages (that I can see). I get the single beep after the self tests just like it is going to load normal. I'll try all the things you said. I'll let you know what happens. Thanks again,
    Vernon
    Scholar:
  • 113 Answers
If the issue was the video card then there would be no display. If there was any display it would be discolored.
Try unplugging any removable media that's hooked up to the computer. After that try to boot it up.
If it still doesn't go anywhere then you most likely have a power supply issue on your hands. try unplugging an unnecessary components inside the computer such as any CD/DVD drives and removing any cards installed. Pretty much everything but the motherboard and the hard drive. If it still doesnt boot properly then you might either have to buy a new power supply or a new motherboard as long as you know your hard drive is good.
The thing si if it was an issue with the hard drive you would get an error message. If you seemed to have left out any error messages please post them.
Posted on Jun 07, 2010
Gateway gt5220 has cmos checksum error - defaults loaded
Open the cpu cabinet cover then pull cmos cell from motherboard for 10 minutes then all settings defaults.Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then set bios settings.Let me know if you need further assistance.Thanks for using FixYa
Nov 18, 2011 | Gateway GT5220 PC Desktop
My gateway 2118u netbook will not boot or turn off the screen says: For Atheros PCIE Ethernet Controller v2.0.0.9(05/08/09) Check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable...
Can you access your BIOS when you turn on the computer?
Somewhere in the BIOS you may have inadvertently changed the netbook to boot from the "Network via PXE" instead of from your local hard drive.
To enter the BIOS, you must restart the PC and enter BIOS setup or BIOS features by pressing Delete or another hardware specific key on BIOS screen startup.
From there, you should encounter a series of menus that you can navigate only with the keyboard... not the mouse. With luck, you will find a boot menu option that you can correct.
Make sure you save your choices on exiting and restart your PC. With a little bit of trial and error, you should be able to coax your netbook to boot from its internal driver.
Sep 09, 2010 | Gateway LT2001u Netbook
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
My keyboard on my other computer is not working - I can't type my password in so I can start my computer -- the computer seems to be working ok! Its a gateway computer
Two things are a possiblity
1. Your keyboard has a short, and you have to get a new keyboard.
Or
2. The cable is unplugged (I'm sure you've checked) but hey it's a possiblity
May 13, 2010 | Gateway GT5220 PC Desktop
No video
change the boot sequence from the BIOS and set the first boot to the Hard disk and check.
Nov 11, 2009 | Gateway GT5220 PC Desktop
No video, shows orange light on front which gateway says video
it sounds like your hardware is not compatable with the update. if you can restart the computer and press f12 to boot to safe mode you should be able to open the device manager from Run: by typing devmgmt.msc, find the video adapter under 'display adapters', double click your adapter to bring up the properties window, click the 'driver' tab and click roll back driver
hope this helps. please rate me and thanks for choosing enterprise computing solutions...
Sep 30, 2009 | Gateway GT5220 PC Desktop
I have bought a new Lexmark x5650 Printer. The setup all went fine but everytime i boot my PC running Windows XP the screen just hangs. When you take the USB cable out of the Printer the PC carries on...
Issue: Computer will not boot with the device connected via USB to the PC
Solution: Disable USB Emulation (legacy support) in the computer BIOS
Turning off USB Emulation (legacy support) in the computer's BIOS
The following steps are for Dell computers. If this issue is occurring on another brand computer, the process of entering the computer's BIOS may be different. Additionally, the steps to make changes may differ as well. Refer to the computer's documentation to verify the appropriate steps to disable USB Emulation.
For Dell computers, perform the following steps:
While rebooting the computer, press the <F2> key to enter the System Setup (BIOS).
Press the Down Arrow <?!> key repeatedly until 'Integrated Devices' is highlighted.
Press <Enter> and another window appears.
Press the Down Arrow <?!> key repeatedly until 'USB Emulation' is highlighted.
Press the Plus <+> key to change the value to 'OFF'.
Press the <Esc> key to exit this window.
Press the <Esc> key again to exit the System Setup (BIOS).
When the message "Do You Want to Save Changes And Exit" appears, press the <Enter> key indicating Yes to save changes. The system will reboot.
Jul 21, 2009 | Lexmark X5650 All-in-One InkJet Printer
COMPUTER WILL NOT BOOT
This does not sound like a power supply issuse
Try This:
tap F8 while booting the PC
This should take you to the Advanced Boot option window
Use you up & down keys: Safe mode With Command propmts(Enter)
Operating System (Enter)
Sign in under your user name( or owner)
once at a command prompt (Black Screen)
Tyoe chkdsk /r (Enter)
You will get a message ( This valume is in use would you like to start a chkdsk on reboot (Y) (Enter) Reboot PC
This should start a chkdsk after the chkdsk is complete reboot the PC you should go to you profile (desktop with Icons)
Good Luck
Dr Geek MD
Feb 22, 2009 | Gateway GT5220 PC Desktop
What to do after installing new hard drive on Gateway Desktop
your machine is looking for the original HD..boot your pc up with the cd that came with machine(restore) but before it gets to the desktop try getting into setup and change the boot sequence to cd rom as 1st boot then hd and so on/ save and exit when it reboots it will ask you..hit a key to boot from cd rom..then you can do as you please
Aug 27, 2008 | Gateway GT5220 PC Desktop
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
